Up to 20% off select tools
AlphaSmart Pro Front Panel Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
23
All Time:
730
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The front panel may need to be replaced if it is cracked or damaged.
    1. AlphaSmart Pro Front Panel Replacement, Separating Panels: step 1, image 1 of 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: step 1, image 2 of 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: step 1, image 3 of 3
      • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
      • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
      • Carefully separate the front panel from the back panel.
      • Notice that the front and back panels are still connected by a ribbon cable.
      Ask FixBot
    2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: step 2, image 1 of 2 AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: step 2, image 2 of 2
      • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
      • Gently pull up on the connector to completely remove the connector from the socket.
      • You are now able to separate the front panel from the back panel.
      Ask FixBot
    3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: step 3, image 1 of 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: step 3, image 2 of 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: step 3, image 3 of 3
      • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
      • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
      Ask FixBot
Author
with
Nathan Smith
22 Reputation
2 Guides authored
Clemson, Team 1-1, Benson Fall 2014 Member of Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 730
