Up to 20% off select tools
AlphaSmart Pro Batteries Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
97
All Time:
1,068
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide teaches you how to remove the battery cover and batteries.
    1. AlphaSmart Pro Batteries Replacement, Removing The Battery Cover.: step 1, image 1 of 3 AlphaSmart Pro Batteries Replacement, Removing The Battery Cover.: step 1, image 2 of 3 AlphaSmart Pro Batteries Replacement, Removing The Battery Cover.: step 1, image 3 of 3
      • Before attempting to remove batteries, make sure the device is turned off.
      • Locate the battery compartment on the back of the AlphaSmart Pro.
      • Push the tab inward and lift up. This will detach the cover from the device.
      Ask FixBot
    2. AlphaSmart Pro Batteries Replacement, Removing The Batteries: step 2, image 1 of 2 AlphaSmart Pro Batteries Replacement, Removing The Batteries: step 2, image 2 of 2
      • Remove each battery by using your fingers or the spudger to pry them from the compartment.
      Ask FixBot
Author
with
Ashley Orr
142 Reputation
2 Guides authored
Clemson, Team 1-1, Benson Fall 2014 Member of Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 97
All Time: 1,068
