Alldaymall A88X LCD Screen Replacement
    1. Alldaymall A88X LCD Screen Replacement, Alldaymall A88X Back Cover: step 1, image 1 of 3 Alldaymall A88X LCD Screen Replacement, Alldaymall A88X Back Cover: step 1, image 2 of 3 Alldaymall A88X LCD Screen Replacement, Alldaymall A88X Back Cover: step 1, image 3 of 3
      • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
      • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
      • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
      Ask FixBot
    2. Alldaymall A88X LCD Screen Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
      • When removing the speaker, make sure not to disconnect the wires in any way.
      • After the speaker has been removed, place the rear panel aside.
      Ask FixBot
    1. Alldaymall A88X LCD Screen Replacement, Speaker: step 3, image 1 of 3 Alldaymall A88X LCD Screen Replacement, Speaker: step 3, image 2 of 3 Alldaymall A88X LCD Screen Replacement, Speaker: step 3, image 3 of 3
      • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
      • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
      Ask FixBot
    2. Alldaymall A88X LCD Screen Replacement: step 4, image 1 of 3 Alldaymall A88X LCD Screen Replacement: step 4, image 2 of 3 Alldaymall A88X LCD Screen Replacement: step 4, image 3 of 3
      Buy
      • Using a pair of tweezers, begin separating the tape downwards from the back panel.
      • Pull the tape away from the wire bundle beneath.
      • Isolate the wire running from the speaker to the motherboard.
      Ask FixBot
    3. Alldaymall A88X LCD Screen Replacement: step 5, image 1 of 3 Alldaymall A88X LCD Screen Replacement: step 5, image 2 of 3 Alldaymall A88X LCD Screen Replacement: step 5, image 3 of 3
      • Desolder the speaker wires from the motherboard.
      Ask FixBot
    1. Alldaymall A88X LCD Screen Replacement, Camera: step 6, image 1 of 3 Alldaymall A88X LCD Screen Replacement, Camera: step 6, image 2 of 3 Alldaymall A88X LCD Screen Replacement, Camera: step 6, image 3 of 3
      • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
      • After the battery is separated from the panel make sure to place it face down above the tablet itself.
      • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
      Ask FixBot
    2. Alldaymall A88X LCD Screen Replacement: step 7, image 1 of 2 Alldaymall A88X LCD Screen Replacement: step 7, image 2 of 2
      • Desolder the wires that connect the battery to the motherboard.
      Ask FixBot
    3. Alldaymall A88X LCD Screen Replacement: step 8, image 1 of 2 Alldaymall A88X LCD Screen Replacement: step 8, image 2 of 2
      Buy
      • Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
      Ask FixBot
    4. Alldaymall A88X LCD Screen Replacement: step 9, image 1 of 3 Alldaymall A88X LCD Screen Replacement: step 9, image 2 of 3 Alldaymall A88X LCD Screen Replacement: step 9, image 3 of 3
      • Using a pair of tweezers begin to peel the antenna from the metal panel.
      • Work your way down until the antenna is completely removed.
      • Be careful not deform the antenna or sever its connection.
      Ask FixBot
    5. Alldaymall A88X LCD Screen Replacement: step 10, image 1 of 1
      • Using a pair of tweezers remove the tape securing the cameras to the back panel.
      Ask FixBot
    6. Alldaymall A88X LCD Screen Replacement: step 11, image 1 of 1
      • Using a plastic opening tool lift up the flap on the ribbon cable receptacle.
      Ask FixBot
    7. Alldaymall A88X LCD Screen Replacement: step 12, image 1 of 2 Alldaymall A88X LCD Screen Replacement: step 12, image 2 of 2
      • Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
      Ask FixBot
    1. Alldaymall A88X LCD Screen Replacement, Motherboard: step 13, image 1 of 3 Alldaymall A88X LCD Screen Replacement, Motherboard: step 13, image 2 of 3 Alldaymall A88X LCD Screen Replacement, Motherboard: step 13, image 3 of 3
      Buy
      • Use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
      • Using a pair of tweezers remove the ribbon cable from its receptacle.
      Ask FixBot
    2. Alldaymall A88X LCD Screen Replacement: step 14, image 1 of 3 Alldaymall A88X LCD Screen Replacement: step 14, image 2 of 3 Alldaymall A88X LCD Screen Replacement: step 14, image 3 of 3
      • Now on the left ribbon cable use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
      Ask FixBot
    3. Alldaymall A88X LCD Screen Replacement: step 15, image 1 of 2 Alldaymall A88X LCD Screen Replacement: step 15, image 2 of 2
      • Desolder the wires that connect the backlight to the motherboard.
      Ask FixBot
    4. Alldaymall A88X LCD Screen Replacement: step 16, image 1 of 3 Alldaymall A88X LCD Screen Replacement: step 16, image 2 of 3 Alldaymall A88X LCD Screen Replacement: step 16, image 3 of 3
      • Using a PH0 screw bit unscrew the three 3mm screws securing the motherboard to the back panel.
      Ask FixBot
    5. Alldaymall A88X LCD Screen Replacement: step 17, image 1 of 1
      • Carefully lift up on the motherboard from its housing.
      Ask FixBot
    1. Alldaymall A88X LCD Screen Replacement, LCD Screen and Touch Sensor Assembly: step 18, image 1 of 3 Alldaymall A88X LCD Screen Replacement, LCD Screen and Touch Sensor Assembly: step 18, image 2 of 3 Alldaymall A88X LCD Screen Replacement, LCD Screen and Touch Sensor Assembly: step 18, image 3 of 3
      • Gently pry the brackets holding the touch sensor to the LCD Screen
      • Do not bend the touch sensor to much as it may shatter.
      Ask FixBot
    1. Alldaymall A88X LCD Screen Replacement, LCD Screen: step 19, image 1 of 2 Alldaymall A88X LCD Screen Replacement, LCD Screen: step 19, image 2 of 2
      • Set the touch sensor aside.
      Ask FixBot
Drhaber
985 Reputation
7 Guides authored
USF Tampa, Team 4-1, Lacy Spring 2016 Member of USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 1,741
