Alienware m15 R6 Wireless card Replacement
    1. Alienware m15 R6 Wireless card Replacement, Base Cover: step 1, image 1 of 1
      • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
      • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
      • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
      Ask FixBot
    2. Alienware m15 R6 Wireless card Replacement: step 2, image 1 of 1
      • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
      • Lift the base cover off the palm-rest and keyboard assembly.
      Ask FixBot
    3. Alienware m15 R6 Wireless card Replacement: step 3, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Turn your computer over and press the power button for 20 seconds to drain the flea power
      Ask FixBot
    1. Alienware m15 R6 Wireless card Replacement, Wireless card: step 4, image 1 of 1
      • Lift the system board Mylar to access the wireless card.
      Ask FixBot
    2. Alienware m15 R6 Wireless card Replacement: step 5, image 1 of 1
      • Remove the screw (M2x4) that secures the wireless-card bracket to the system board and palm-rest and keyboard assembly.
      • Lift the wireless-card bracket off the wireless card.
      • Disconnect the antenna cables from the wireless card.
      • Slide and remove the wireless card from the wireless-card slot.
      Ask FixBot
Andrzej
1,732 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 77
All Time: 558
