Alienware m15 R6 USB board Replacement
    1. Alienware m15 R6 USB board Replacement, Base Cover: step 1, image 1 of 1
      • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
      • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
      • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
      Ask FixBot
    2. Alienware m15 R6 USB board Replacement: step 2, image 1 of 1
      • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
      • Lift the base cover off the palm-rest and keyboard assembly.
      Ask FixBot
    3. Alienware m15 R6 USB board Replacement: step 3, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Turn your computer over and press the power button for 20 seconds to drain the flea power
      Ask FixBot
    1. Alienware m15 R6 USB board Replacement, Battery: step 4, image 1 of 1
      • Disconnect the battery cable from the system board (applicable only if not disconnected earlier).
      • NOTE: After removing the battery, store the battery cable safely. The replacement battery will not be shipped with thebattery cable. If you want to replace the battery cable, it has to be purchased separately.
      • Remove the four screws (M2x4) that secure the battery to the palm-rest and keyboard assembly.
      • Remove the four screws (M2x3) that secure the battery to the palm-rest and keyboard assembly.
      • Lift the battery off the palm-rest and keyboard assembly.
      Ask FixBot
    1. Alienware m15 R6 USB board Replacement, Removing the solid-state drive in SSD slot one: step 5, image 1 of 2 Alienware m15 R6 USB board Replacement, Removing the solid-state drive in SSD slot one: step 5, image 2 of 2
      • Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and the system board.
      • Lift the thermal shield off the solid-state drive.
      • Slide and lift the solid-state drive off the solid-state drive slot on the system board.
      Ask FixBot
    2. Alienware m15 R6 USB board Replacement, Procedure to move the screw mount in SSD slot one: step 6, image 1 of 1
      • Slide to remove the screw mount from the palm-rest and keyboard assembly.
      • Slide the screw mount into the other screw mount slot on the palm-rest and keyboard assembly.
      Ask FixBot
    1. Alienware m15 R6 USB board Replacement, Removing the solid-state drive in SSD slot two: step 7, image 1 of 2 Alienware m15 R6 USB board Replacement, Removing the solid-state drive in SSD slot two: step 7, image 2 of 2
      • Remove the two screws (M2x4) that secure the thermal shield to the solid-state drive and system board.
      Ask FixBot
    2. Alienware m15 R6 USB board Replacement, Procedure to move the screw mount in SSD slot two: step 8, image 1 of 1
      Ask FixBot
    1. Alienware m15 R6 USB board Replacement, Memory module: step 9, image 1 of 1
      • Lift the system board Mylar to access the memory module.
      • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory modulepops up.
      • Remove the memory module from the memory-module slot.
      Ask FixBot
    1. Alienware m15 R6 USB board Replacement, Wireless card: step 10, image 1 of 1
      • Lift the system board Mylar to access the wireless card.
      Ask FixBot
    2. Alienware m15 R6 USB board Replacement: step 11, image 1 of 1
      • Remove the screw (M2x4) that secures the wireless-card bracket to the system board and palm-rest and keyboard assembly.
      • Lift the wireless-card bracket off the wireless card.
      • Disconnect the antenna cables from the wireless card.
      • Slide and remove the wireless card from the wireless-card slot.
      Ask FixBot
    1. Alienware m15 R6 USB board Replacement, Rear-I/O cover: step 12, image 1 of 1
      • Remove the two screws (M2x4) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
      • Remove the two screws (M2.5x5) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
      • Disconnect the Tron light cable from the system board.
      • Firmly grasp the sides of your computer with both hands and push the rubber feet on the rear I/O-cover outwards with yourthumbs to release the rear I/O-cover from the palm-rest and keyboard assembly.
      • Slide the rear I/O-cover away from the palm-rest and keyboard assembly.
      Ask FixBot
    1. Alienware m15 R6 USB board Replacement, System board: step 13, image 1 of 1
      • The following image indicates the connectors on your system board.
      Ask FixBot
    2. Alienware m15 R6 USB board Replacement: step 14, image 1 of 1
      • Peel the system board Mylar off the system board.
      Ask FixBot
    3. Alienware m15 R6 USB board Replacement: step 15, image 1 of 1
      • Remove the two screws (M2x4) that secure the USB Type-C port bracket to the system board.
      • Remove the USB Type-C port bracket from the system board.
      • Open the latch, and disconnect the display cable from the system board.
      • Disconnect the Alienhead LED cable from the system board.
      • Peel the display cable from the system board.
      • Disconnect the power-adapter port cable from the system board.
      • Peel the power-adapter port cable from the system board.
      • Disconnect the I/O-board cable from the system board.
      Ask FixBot
    4. Alienware m15 R6 USB board Replacement: step 16, image 1 of 1
      • Disconnect the speaker cable from the system board.
      • Open the latch, and disconnect the touchpad cable from the system board.
      • Open the latch, and disconnect the keyboard-controller board-cable from the system board.
      • Open the latch, and disconnect the power-button board cable from the USB board.
      • Open the latch, and disconnect the RGB-IR camera cable from the USB board.
      • Peel the RGB-IR camera cable from the system board.
      Ask FixBot
    5. Alienware m15 R6 USB board Replacement: step 17, image 1 of 1
      • Remove the eight (M2x4) screws that secure the system board to the palm-rest and keyboard assembly. (The USB board and heat sink are attached to the system board.)
      • Lift the system-board assembly off the palm-rest and keyboard assembly. (Before removing the system board, give sufficient time for the heat sink to cool down to avoid injury.)
      • Place the system-board assembly on a clean and flat surface.
      Ask FixBot
    6. Alienware m15 R6 USB board Replacement: step 18, image 1 of 1
      • Turn the system-board assembly over.
      • Remove the USB board.
      • Remove the heat-sink assembly.
      Ask FixBot
    7. Alienware m15 R6 USB board Replacement: step 19, image 1 of 1
      • After performing all the above steps, you are left with the system board.
      Ask FixBot
    1. Alienware m15 R6 USB board Replacement, USB board: step 20, image 1 of 1
      • Remove the two screws (M2x4) that secure the USB board to the system board.
      • Remove the USB board off the system board.
      Ask FixBot
Andrzej
1,732 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 75
All Time: 508
