Alienware m15 R6 Touchpad Replacement
    1. Alienware m15 R6 Touchpad Replacement, Base Cover: step 1, image 1 of 1
      • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
      • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
      • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
      Ask FixBot
    2. Alienware m15 R6 Touchpad Replacement: step 2, image 1 of 1
      • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
      • Lift the base cover off the palm-rest and keyboard assembly.
      Ask FixBot
    3. Alienware m15 R6 Touchpad Replacement: step 3, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Turn your computer over and press the power button for 20 seconds to drain the flea power
      Ask FixBot
    1. Alienware m15 R6 Touchpad Replacement, Battery: step 4, image 1 of 1
      • Disconnect the battery cable from the system board (applicable only if not disconnected earlier).
      • NOTE: After removing the battery, store the battery cable safely. The replacement battery will not be shipped with thebattery cable. If you want to replace the battery cable, it has to be purchased separately.
      • Remove the four screws (M2x4) that secure the battery to the palm-rest and keyboard assembly.
      • Remove the four screws (M2x3) that secure the battery to the palm-rest and keyboard assembly.
      • Lift the battery off the palm-rest and keyboard assembly.
      Ask FixBot
    1. Alienware m15 R6 Touchpad Replacement, Touchpad: step 5, image 1 of 1
      • Remove the speaker cable from the routing guides on the palm-rest and keyboard assembly.
      • Open the latch and disconnect the touchpad cable from the system board.
      • Open the latch and disconnect the touchpad cable from the touchpad.
      • Remove the two (M2.5x2.5) screws that secure the touchpad bracket to the palm-rest and keyboard assembly.
      • Lift the touchpad bracket off the palm-rest and keyboard assembly.
      • Remove the two (M2x2) screws that secure the touchpad to the palm-rest and keyboard assembly.
      • Lift the touchpad off the palm-rest and keyboard assembly.
      Ask FixBot
Andrzej
1,732 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 67
All Time: 804
