Alienware m15 R6 Power-adapter port Replacement
    1. Alienware m15 R6 Power-adapter port Replacement, Base Cover: step 1, image 1 of 1
      • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
      • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
      • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
      Ask FixBot
    2. Alienware m15 R6 Power-adapter port Replacement: step 2, image 1 of 1
      • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
      • Lift the base cover off the palm-rest and keyboard assembly.
      Ask FixBot
    3. Alienware m15 R6 Power-adapter port Replacement: step 3, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Turn your computer over and press the power button for 20 seconds to drain the flea power
      Ask FixBot
    1. Alienware m15 R6 Power-adapter port Replacement, Rear-I/O cover: step 4, image 1 of 1
      • Remove the two screws (M2x4) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
      • Remove the two screws (M2.5x5) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
      • Disconnect the Tron light cable from the system board.
      • Firmly grasp the sides of your computer with both hands and push the rubber feet on the rear I/O-cover outwards with yourthumbs to release the rear I/O-cover from the palm-rest and keyboard assembly.
      • Slide the rear I/O-cover away from the palm-rest and keyboard assembly.
      Ask FixBot
    1. Alienware m15 R6 Power-adapter port Replacement, Power-adapter port: step 5, image 1 of 1
      • Open the latch and disconnect the display cable from the system board.
      • Disconnect the Alienhead LED cable from the system board.
      • Peel the display cable from the system board and remove the display cable from the slot on the system board.
      • Lift the system board Mylar next to the left fan to access the power-adapter port.
      • Remove the two screws (M2x4) on the power-adapter port-bracket that secures the power-adapter port bracket to the systemboard.
      • Lift the power-adapter port-bracket off the system board.
      • Disconnect the power-adapter port-cable from the system board.
      • Peel and lift the power-adapter port, along with its cable, off the system board.
      Ask FixBot
Andrzej
1,732 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 33
All Time: 969
