Alienware m15 R6 I/O board Replacement
    1. Alienware m15 R6 I/O board Replacement, Base Cover: step 1, image 1 of 1
      • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
      • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
      • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
      Ask FixBot
    2. Alienware m15 R6 I/O board Replacement: step 2, image 1 of 1
      • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
      • Lift the base cover off the palm-rest and keyboard assembly.
      Ask FixBot
    3. Alienware m15 R6 I/O board Replacement: step 3, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Turn your computer over and press the power button for 20 seconds to drain the flea power
      Ask FixBot
    1. Alienware m15 R6 I/O board Replacement, I/O board: step 4, image 1 of 1
      • Lift the system board Mylar and open the latch to disconnect the I/O-board cable from the system board.
      • Open the latch to disconnect the I/O-board cable from the I/O board.
      • Remove the screw (M2x4) that secures the I/O board to the palm-rest and keyboard assembly.
      • Loosen the captive screw (M2x2) that secures the I/O board to the palm-rest and keyboard assembly. (skip for NVIDIA GeForce RTX 3050 Ti discrete GPU controller)
      • Lift the I/O board off the palm-rest and keyboard assembly.
      Ask FixBot
Andrzej
1,732 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 413
