Up to 20% off select tools
Alienware m15 R6 Display Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
111
All Time:
2,177
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Prerequisites 1. Follow the procedure in Before working inside your computer.
    1. Alienware m15 R6 Display Replacement, Base Cover: step 1, image 1 of 1
      • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
      • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
      • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
      Ask FixBot
    2. Alienware m15 R6 Display Replacement: step 2, image 1 of 1
      • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
      • Lift the base cover off the palm-rest and keyboard assembly.
      Ask FixBot
    3. Alienware m15 R6 Display Replacement: step 3, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Turn your computer over and press the power button for 20 seconds to drain the flea power
      Ask FixBot
    1. Alienware m15 R6 Display Replacement, Rear-I/O cover: step 4, image 1 of 1
      • Remove the two screws (M2x4) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
      • Remove the two screws (M2.5x5) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
      • Disconnect the Tron light cable from the system board.
      • Firmly grasp the sides of your computer with both hands and push the rubber feet on the rear I/O-cover outwards with yourthumbs to release the rear I/O-cover from the palm-rest and keyboard assembly.
      • Slide the rear I/O-cover away from the palm-rest and keyboard assembly.
      Ask FixBot
    1. Alienware m15 R6 Display Replacement, Display: step 5, image 1 of 1
      • Open the latch and disconnect the display cable from the system board.
      • Disconnect the Alienhead LED cable from the system board.
      • Disconnect the RGB-IR camera cable from the USB board.
      • Lift the system board Mylar and peel the tapes that secure the RGB-IR camera cable to the system board.
      • Lift the RGB-IR camera cable off the system board.
      • Turn the computer over and place the computer on a clean and flat surface.
      • Remove the display cable from the routing guides on the palm-rest and keyboard assembly.
      • Remove the RGB-IR camera cable from the routing guides on the palm-rest and keyboard assembly.
      Ask FixBot
    2. Alienware m15 R6 Display Replacement: step 6, image 1 of 1
      • Remove the six screws (M2.5x5) that secure the display hinges to the palm-rest and keyboard assembly.
      • Lift the display assembly off the palm-rest and keyboard assembly.
      Ask FixBot
    3. Alienware m15 R6 Display Replacement: step 7, image 1 of 1
      • After performing all the above steps, you are left with the display assembly.
      Ask FixBot
Author
with
Andrzej
1,732 Reputation
18 Guides authored
1 Guide Comment
How do you replace the LCD ribbon cable? It seems to be glued to the screen. I just need to replace that cable because it broke when I had to disconnect it to replace the charging port. :(
Melissa Ceyrolles - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 111
All Time: 2,177
