Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓Before you start this project, you should take proper precautions. Before you start anything, you need to unplug the computer from the wall. Unplugging the computer is a must to avoid electrocution. It is recommended to take precautions against ESD by using an anti-static mat and a grounding cable. The only tool you will need for this fix is a screwdriver. You will also need a replacement CPU and thermal grease.
The first step is to unscrew this screw. After that you want to slide the case cover off of the computer.
To reassemble your device, follow these instructions in reverse order with the new processor installed. Don't forget to apply thermal grease to the new CPU.
2 other people completed this guide.
