Up to 20% off select tools
Alienware X51 R1/R2/R3 RAM Replacement
Views: 7.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
139
All Time:
7,537
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
Before starting this guide, You should take the proper precautions to prevent damage to your machine, and to you. Please do the following before starting this guide:
  1. Unplug the computer from the external power supply
  2. Press (and hold) the power button for 3 seconds. (This will ensure that the system uses any excess power in the board)
An ESD Strap is recommended as this prevents damage to your computer
    1. Alienware X51 R1/R2/R3 RAM Replacement, Remove Panel Screw: step 1, image 1 of 1
      • First, turn the computer so you can see the rear panel. Remove the small screw to the right (or above, if the system is on its side) of the audio jacks.
      • Once the screw is removed, use both hands to push the side panel down and towards the front of the case.
      Ask FixBot
    2. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect LED Control Cable: step 2, image 1 of 1
      • Lift the side panel off, and gently flip it over the top of the system, being careful not to break the LED control cable. Unplug its connector and set the case panel to the side.
      Ask FixBot
    3. Alienware X51 R1/R2/R3 RAM Replacement, Remove Fan Screws: step 3, image 1 of 1
      • Next, remove the screws securing the plastic air re-director (not shown in picture) to the fan, and gently lift it out of the case. Set aside and move to the next step.
      Ask FixBot
    4. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect/Remove the DVD Drive: step 4, image 1 of 1
      • Unplug the SATA cable at the base of the DVD drive circled in blue. This cable will have a lot of tension on it, but do not worry. Just be careful not to yank on it too much.
      • You will then unscrew the screw securing the DVD drive to the case (circled in red). Once the screw is removed, remove the DVD drive and set to the side.
      Ask FixBot
    5. Alienware X51 R1/R2/R3 RAM Replacement: step 5, image 1 of 1
      • Now, push the white latch (circled in red) DOWN and pull the ram card straight up to a ~45 degree angle. Pull up and out, towards the latch side, and set aside.
      Ask FixBot
    6. Alienware X51 R1/R2/R3 RAM Replacement, Insert New Ram Card: step 6, image 1 of 1
      • You will insert the new DIMM. Push the side opposite to the latch in first, being sure that the notch in the connector matches the location on the ram DIMM.
      • Insert at a ~45 degree angle and push straight down into the socket, being sure that the latch clicks.
      • DO NOT FORCE THE DIMM IN. Rotate the card and try again if the card will not go into the port.
      Ask FixBot
4 other people completed this guide.
Author
with
Daniel Niles
163 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 139
All Time: 7,537
