Up to 20% off select tools
Alienware X51 Fan Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
103
All Time:
1,089
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
If your Alienware X51 PC begins to freeze up or shut down at random points, you may need to replace the fan (refer to the Troubleshooting Guide for more details). Replacing the fan, which helps with cooling down the processor, is as simple as unscrewing the fan. This replacement can be applied to the Alienware X51 R1, as well as the other models (the R2 or R3).
    1. Alienware X51 Fan Replacement, Front Panel: step 1, image 1 of 1
      • Place the PC so the name "Alienware" is on top and facing you.
      • Slide the front panel towards you and lift up.
      Ask FixBot
    2. Alienware X51 Fan Replacement: step 2, image 1 of 1
      • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
      • Remove the front panel from the rest of the device.
      Ask FixBot
    1. Alienware X51 Fan Replacement, Fan: step 3, image 1 of 2 Alienware X51 Fan Replacement, Fan: step 3, image 2 of 2
      • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
      • Remove the protector holding the fan in.
      Ask FixBot
    2. Alienware X51 Fan Replacement: step 4, image 1 of 1
      • Disconnect the Molex KK connector from the fan.
      Ask FixBot
    3. Alienware X51 Fan Replacement: step 5, image 1 of 3 Alienware X51 Fan Replacement: step 5, image 2 of 3 Alienware X51 Fan Replacement: step 5, image 3 of 3
      • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
      • Gently pull back the clips and remove the fan by pulling it out.
      Ask FixBot
2 other people completed this guide.
Author
with
Braedon
402 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 103
All Time: 1,089
