Up to 20% off select tools
Alienware X51 Disc Drive Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
79
All Time:
1,128
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 5 minutes
Difficulty: Easy
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
If your Alienware X51 disc drive is damaged or broken, it's crucial to replace it promptly to ensure uninterrupted performance. The replacement process should be straightforward, allowing you to resume using your Alienware X51 quickly. The disc drive is essential for reading and accessing discs, and when malfunctioning, it can lead to various symptoms such as difficulty reading discs or complete failure to function. Refer to our troubleshooting guide for detailed assistance in diagnosing and addressing these issues effectively.
    1. Alienware X51 Disc Drive Replacement, Front Panel: step 1, image 1 of 1
      • Place the PC so the name "Alienware" is on top and facing you.
      • Slide the front panel towards you and lift up.
      Ask FixBot
    2. Alienware X51 Disc Drive Replacement: step 2, image 1 of 1
      • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
      • Remove the front panel from the rest of the device.
      Ask FixBot
    1. Alienware X51 Disc Drive Replacement, Disc Drive: step 3, image 1 of 2 Alienware X51 Disc Drive Replacement, Disc Drive: step 3, image 2 of 2
      • Disconnect the optical-drive data and power cable.
      Ask FixBot
    2. Alienware X51 Disc Drive Replacement: step 4, image 1 of 1
      • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
      • Remove the disc drive from the PC.
      Ask FixBot
Author
with
Zach Li
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 79
All Time: 1,128
