Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
54
All Time:
303
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 55 minutes - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help you replace the on/off switch for the Alienware Pro Wireless Gaming Mouse (model name PRO-MS and PRO-M-D). The on/off switch is a mechanical control that physically breaks the circuit between the battery and the motherboard. Failure of the on/off switch will result in the mouse being stuck “on” leading to rapid battery drain or the mouse being stuck “off” and not powering on, even with a charged battery.
Before replacing the on/off switch, please refer to the troubleshooting guides. The prerequisite guides will show you exactly how to disassemble the mouse to access the on/off switch. This guide will walk you through step by step how to remove the on/off switch.
Caution: Be careful when handling electronic components and wash your hands after the repair.
Before you begin the repair, power off and disconnect your mouse from any devices or the charger.
Tools
    1. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Feet: step 1, image 1 of 3 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Feet: step 1, image 2 of 3 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Feet: step 1, image 3 of 3
      • Flip the mouse over so the bottom is facing up..
      • Use an opening pick to gently peel the mouse foot off the bottom case.
      • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
      Ask FixBot
    2. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 2, image 1 of 2 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 2, image 2 of 2
      • Peel and remove the other mouse foot.
      Ask FixBot
    1. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Battery: step 3, image 1 of 1
      • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
      Ask FixBot
    2. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 4, image 1 of 3 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 4, image 2 of 3 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 4, image 3 of 3
      • Use your hands or a spudger to separate the bottom and top of the mouse.
      • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
      • You may hear a cracking sound when the clips are released.
      Ask FixBot
    3. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 5, image 1 of 2 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 5, image 2 of 2
      • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
      • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
      Ask FixBot
    4. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 6, image 1 of 2 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 6, image 2 of 2
      • The battery is glued to the case.
      • Use an opening tool or spudger to loosen the adhesive under the battery.
      • Remove the battery.
      Ask FixBot
    1. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Side Button: step 7, image 1 of 2 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Side Button: step 7, image 2 of 2
      • Pinch the upper part of the ribbon cable.
      • Pull the ribbon cable gently to detach it from the socket on the motherboard.
      • Make sure the ribbon line is facing the correct direction when reassembling the controller.
      Ask FixBot
    2. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 8, image 1 of 2 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 8, image 2 of 2
      • Lift the side button panel from the plastic frame.
      Ask FixBot
    1. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Scroll Wheel: step 9, image 1 of 3 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Scroll Wheel: step 9, image 2 of 3 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Scroll Wheel: step 9, image 3 of 3
      • Hold the scroll wheel encoder steady and gently pull the scroll wheel to the right to remove it.
      • Only light force is needed—be gentle to avoid damaging nearby parts.
      Ask FixBot
    1. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, Motherboard: step 10, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two 5 mm screws at the bottom of the motherboard.
      Ask FixBot
    2. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 11, image 1 of 1
      • Gently pull the side clip away from the motherboard to release it from the plastic frame.
      • Use a spudger to release the board from the clips if that is easier.
      Ask FixBot
    3. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 12, image 1 of 2 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 12, image 2 of 2
      • Bend the front nose of the mouse body to release the motherboard.
      • Remove the motherboard from the bottom case.
      Ask FixBot
    1. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, On/Off Switch: step 13, image 1 of 2 Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement, On/Off Switch: step 13, image 2 of 2
      • Pull back one of the two plastic retaining tabs.
      Ask FixBot
    2. Alienware Pro Wireless Gaming Mouse On/Off Switch Replacement: step 14, image 1 of 1
      • Remove the plastic On/Off switch.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Samuel Blanton
381 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 54
All Time: 303
