Alienware Pro Wireless Gaming Mouse Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
61
All Time:
316
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will help you to replace the motherboard for the Alienware Pro Wireless Gaming Mouse (model name PRO-MS and PRO-M-D).
The motherboard is the central computing component that allows all of the physical inputs on the mouse to be translated into the computer. This guide will show you how to remove all the parts necessary to access the motherboard and how to remove the motherboard itself.
Please note that the motherboard is prone to damage, so be careful when replacing it. Hold the new motherboard by the edges and avoid touching the board surface.
Before you begin the repair, power off the mouse and disconnect it from any devices or the charger.
Tools
    1. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Feet: step 1, image 1 of 3 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Feet: step 1, image 2 of 3 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Feet: step 1, image 3 of 3
      • Flip the mouse over so the bottom is facing up..
      • Use an opening pick to gently peel the mouse foot off the bottom case.
      • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
      Ask FixBot
    2. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 2, image 1 of 2 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 2, image 2 of 2
      • Peel and remove the other mouse foot.
      Ask FixBot
    1. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Battery: step 3, image 1 of 1
      • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
      Ask FixBot
    2. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 4, image 1 of 3 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 4, image 2 of 3 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 4, image 3 of 3
      • Use your hands or a spudger to separate the bottom and top of the mouse.
      • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
      • You may hear a cracking sound when the clips are released.
      Ask FixBot
    3. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 5, image 1 of 2 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 5, image 2 of 2
      • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
      • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
      Ask FixBot
    4. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 6, image 1 of 2 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 6, image 2 of 2
      • The battery is glued to the case.
      • Use an opening tool or spudger to loosen the adhesive under the battery.
      • Remove the battery.
      Ask FixBot
    1. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Side Button: step 7, image 1 of 2 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Side Button: step 7, image 2 of 2
      • Pinch the upper part of the ribbon cable.
      • Pull the ribbon cable gently to detach it from the socket on the motherboard.
      • Make sure the ribbon line is facing the correct direction when reassembling the controller.
      Ask FixBot
    2. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 8, image 1 of 2 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 8, image 2 of 2
      • Lift the side button panel from the plastic frame.
      Ask FixBot
    1. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Scroll Wheel: step 9, image 1 of 3 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Scroll Wheel: step 9, image 2 of 3 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Scroll Wheel: step 9, image 3 of 3
      • Hold the scroll wheel encoder steady and gently pull the scroll wheel to the right to remove it.
      • Only light force is needed—be gentle to avoid damaging nearby parts.
      Ask FixBot
    1. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Motherboard: step 10, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two 5 mm screws at the bottom of the motherboard.
      Ask FixBot
    2. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 11, image 1 of 1
      • Gently pull the side clip away from the motherboard to release it from the plastic frame.
      • Use a spudger to release the board from the clips if that is easier.
      Ask FixBot
    3. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 12, image 1 of 2 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: step 12, image 2 of 2
      • Bend the front nose of the mouse body to release the motherboard.
      • Remove the motherboard from the bottom case.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Matt Seay
407 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 61
All Time: 316
