Alienware P18G M14X R1 Optical Drive Replacement
    1. Alienware P18G M14X R1 Optical Drive Replacement, Back Cover: step 1, image 1 of 1
      • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
      • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
      Ask FixBot
    2. Alienware P18G M14X R1 Optical Drive Replacement: step 2, image 1 of 1
      • Slide back cover forward using your thumbs.
      Ask FixBot
    3. Alienware P18G M14X R1 Optical Drive Replacement: step 3, image 1 of 1
      • Lift up the cover and set aside exposing the internals of the computer.
      Ask FixBot
    1. Alienware P18G M14X R1 Optical Drive Replacement, Battery: step 4, image 1 of 1
      • Make sure the laptop is turned off before starting.
      • Using PH1 screwdriver loosen the two screws on the right of the battery.
      • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
      Ask FixBot
    2. Alienware P18G M14X R1 Optical Drive Replacement: step 5, image 1 of 2 Alienware P18G M14X R1 Optical Drive Replacement: step 5, image 2 of 2
      • Pull battery up using the tab provided.
      Ask FixBot
    3. Alienware P18G M14X R1 Optical Drive Replacement: step 6, image 1 of 1
      • Disconnect the clip connecting the battery to the computer.
      • Set battery aside.
      Ask FixBot
    1. Alienware P18G M14X R1 Optical Drive Replacement, Optical Drive: step 7, image 1 of 1
      • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
      Ask FixBot
    2. Alienware P18G M14X R1 Optical Drive Replacement: step 8, image 1 of 1
      • Using the plastic opening tool unclip the white connector holding down the orange cable.
      Ask FixBot
    3. Alienware P18G M14X R1 Optical Drive Replacement: step 9, image 1 of 1
      • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
      Ask FixBot
Andonaq Grozdani
892 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 69
All Time: 862
