Up to 20% off select tools
Alienware M18x Internal Fan Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
102
All Time:
1,231
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
There are three internal fans located in the Alienware M18x laptop. This guide will demonstrate how to go about removing said fans.
    1. Alienware M18x Internal Fan Replacement, Internal Fan: step 1, image 1 of 3 Alienware M18x Internal Fan Replacement, Internal Fan: step 1, image 2 of 3 Alienware M18x Internal Fan Replacement, Internal Fan: step 1, image 3 of 3
      • Turn the computer over.
      • Slide the battery latch over and lift the battery out.
      Ask FixBot
    2. Alienware M18x Internal Fan Replacement: step 2, image 1 of 1
      • Unscrew the four indicated screws with a J000 screwdriver.
      Ask FixBot
    3. Alienware M18x Internal Fan Replacement: step 3, image 1 of 2 Alienware M18x Internal Fan Replacement: step 3, image 2 of 2
      • Use the plastic pryer tool to lift the bottom cover off.
      Ask FixBot
    4. Alienware M18x Internal Fan Replacement: step 4, image 1 of 2 Alienware M18x Internal Fan Replacement: step 4, image 2 of 2
      • With the back cover removed, locate the desired fan to replace.
      Ask FixBot
    5. Alienware M18x Internal Fan Replacement: step 5, image 1 of 3 Alienware M18x Internal Fan Replacement: step 5, image 2 of 3 Alienware M18x Internal Fan Replacement: step 5, image 3 of 3
      • Use a J000 screwdriver to loosen the screws that secure the fan(s).
      • There are three internal fans within the laptop. Locate the correct screws to loosen for the desired fan to replace based on the provided corresponding images.
      Ask FixBot
    6. Alienware M18x Internal Fan Replacement: step 6, image 1 of 3 Alienware M18x Internal Fan Replacement: step 6, image 2 of 3 Alienware M18x Internal Fan Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • The fan will be connected to the motherboard by a cable. Use plastic tweezers to gently unplug this connection.
      Ask FixBot
    7. Alienware M18x Internal Fan Replacement: step 7, image 1 of 2 Alienware M18x Internal Fan Replacement: step 7, image 2 of 2
      • The fan is now fully disconnected from the computer. Gently remove the fan by lifting upwards.
      Ask FixBot
Author
with
Jonathan Panella
470 Reputation
2 Guides authored
Cal Poly, Team S21-G1, Banghart Winter 2018 Member of Cal Poly, Team S21-G1, Banghart Winter 2018
CPSU-BANGHART-W18S21G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 102
All Time: 1,231
