Up to 20% off select tools
Alienware M17x RAM Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
65
All Time:
1,080
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your RAM can't keep up with the demands of today's mundane and daily tasks, use this guide to remove and replace your RAM cards.
    1. Alienware M17x RAM Replacement, Battery: step 1, image 1 of 2 Alienware M17x RAM Replacement, Battery: step 1, image 2 of 2
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      Ask FixBot
    2. Alienware M17x RAM Replacement: step 2, image 1 of 1
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      Ask FixBot
    3. Alienware M17x RAM Replacement: step 3, image 1 of 1
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      Ask FixBot
    4. Alienware M17x RAM Replacement: step 4, image 1 of 2 Alienware M17x RAM Replacement: step 4, image 2 of 2
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      Ask FixBot
    1. Alienware M17x RAM Replacement, RAM: step 5, image 1 of 2 Alienware M17x RAM Replacement, RAM: step 5, image 2 of 2
      • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
      Ask FixBot
    2. Alienware M17x RAM Replacement: step 6, image 1 of 2 Alienware M17x RAM Replacement: step 6, image 2 of 2
      • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
      • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
      Ask FixBot
    3. Alienware M17x RAM Replacement: step 7, image 1 of 1
      • Remove the bottom RAM card in a similar manner.
      Ask FixBot
Author
with
Mosier Locke
783 Reputation
5 Guides authored
1 Guide Comment
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
Neil Radtke - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 65
All Time: 1,080
