Alienware M17x P01E Center Control Cover Replacement
    1. Alienware M17x P01E Center Control Cover Replacement, Battery: step 1, image 1 of 1
      • Please power off the computer and deplete the battery before attempting the following step.
      Ask FixBot
    2. Alienware M17x P01E Center Control Cover Replacement: step 2, image 1 of 2 Alienware M17x P01E Center Control Cover Replacement: step 2, image 2 of 2
      • Press down on the battery latch and slide it to the left.
      • Lift the battery out once it pops out.
      Ask FixBot
    1. Alienware M17x P01E Center Control Cover Replacement, Compartment Door: step 3, image 1 of 1
      • Loosen the two silver Phillips #1 screws.
      • The screws are held to the compartment door by a washer and cannot be removed.
      Ask FixBot
    2. Alienware M17x P01E Center Control Cover Replacement: step 4, image 1 of 2 Alienware M17x P01E Center Control Cover Replacement: step 4, image 2 of 2
      • Use your hand to gently lift and remove the compartment door.
      Ask FixBot
    1. Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: step 5, image 1 of 3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: step 5, image 2 of 3 Alienware M17x P01E Center Control Cover Replacement, Center Control Cover: step 5, image 3 of 3
      • Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
      Ask FixBot
    2. Alienware M17x P01E Center Control Cover Replacement: step 6, image 1 of 2 Alienware M17x P01E Center Control Cover Replacement: step 6, image 2 of 2
      • Turn the laptop top side up and fully open the display.
      • The center control panel is between the display and the keyboard. Fully opening the display ensures that there is enough room to pry and lift the center control panel.
      • Pry the center control panel up from its left and right edges with the Spudger.
      • The center control panel may require a decent amount of force to pry free. Do not immediately lift the panel from the laptop once it has been pried free. A cable is connected from the laptop to the center control panel.
      Ask FixBot
    3. Alienware M17x P01E Center Control Cover Replacement: step 7, image 1 of 2 Alienware M17x P01E Center Control Cover Replacement: step 7, image 2 of 2
      • Lift the center control panel from the laptop.
      • Tilt the center control panel away from the display carefully.
      • Lift the latch open to remove the cable connecting from the laptop to the center control panel.
      Ask FixBot
Grant Dolmat
328 Reputation
2 Guides authored
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Member of CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 68
All Time: 818
