Alienware M17x Motherboard Replacement
    1. Alienware M17x Motherboard Replacement, Battery: step 1, image 1 of 2 Alienware M17x Motherboard Replacement, Battery: step 1, image 2 of 2
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      Ask FixBot
    2. Alienware M17x Motherboard Replacement: step 2, image 1 of 1
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      Ask FixBot
    3. Alienware M17x Motherboard Replacement: step 3, image 1 of 1
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      Ask FixBot
    4. Alienware M17x Motherboard Replacement: step 4, image 1 of 2 Alienware M17x Motherboard Replacement: step 4, image 2 of 2
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      Ask FixBot
    1. Alienware M17x Motherboard Replacement, Motherboard: step 5, image 1 of 1
      • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
      • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
      • Twelve 5.5 mm Phillips #0 main frame screws.
      • Six 3.5 mm Phillips #0 fan screws.
      • Four 3.5 mm Phillips #0 internal compartment screws.
      • Eight 3.5 mm Phillips #0 Hard Drive screws.
      • Four 3.5 mm Phillips #0 CD Drive screws.
      • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
      Ask FixBot
    2. Alienware M17x Motherboard Replacement: step 6, image 1 of 3 Alienware M17x Motherboard Replacement: step 6, image 2 of 3 Alienware M17x Motherboard Replacement: step 6, image 3 of 3
      • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
      • Use a plastic opening tool to pry the keyboard from the base of the computer.
      Ask FixBot
    3. Alienware M17x Motherboard Replacement: step 7, image 1 of 1
      • Remove five 3.5 mm Phillips #0 screws from the motherboard.
      • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
      • Lift the motherboard at an angle and remove it from the computer base.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 87
All Time: 2,614
