Alienware M17x Hard Drive Replacement
    1. Alienware M17x Hard Drive Replacement, Battery: step 1, image 1 of 2 Alienware M17x Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      Ask FixBot
    2. Alienware M17x Hard Drive Replacement: step 2, image 1 of 1
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      Ask FixBot
    3. Alienware M17x Hard Drive Replacement: step 3, image 1 of 1
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      Ask FixBot
    4. Alienware M17x Hard Drive Replacement: step 4, image 1 of 2 Alienware M17x Hard Drive Replacement: step 4, image 2 of 2
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      Ask FixBot
    1. Alienware M17x Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • With the laptop flipped over, cover removed, and battery removed; continue by locating your hard drive(s).
      Ask FixBot
    2. Alienware M17x Hard Drive Replacement: step 6, image 1 of 3 Alienware M17x Hard Drive Replacement: step 6, image 2 of 3 Alienware M17x Hard Drive Replacement: step 6, image 3 of 3
      • Remove the eight 3.5 mm Phillips #0 screws.
      • Remove the hard drive(s), using the Plastic Opening Tool by lifting on the edges and pulling the hard drive up and out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 65
All Time: 2,914
