Tools
Spudger4.9
Introduction
Go to step 1 ↓If your screen is damaged or doesn't work like it used to, use this guide to remove and replace your display assembly.
Flip the laptop back over so that the Alienware logo faces the ceiling then open the lid to view the screen.
Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
Use the spudger to remove the siding from the bottom of the frame near the hinges.
Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
