Up to 20% off select tools
Alienware M17x Battery Replacement
Views: 4K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
66
All Time:
3,978
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your battery can't keep a charge or drains quickly, use this guide to remove and replace your battery.
    1. Alienware M17x Battery Replacement, Battery: step 1, image 1 of 2 Alienware M17x Battery Replacement, Battery: step 1, image 2 of 2
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      Ask FixBot
    2. Alienware M17x Battery Replacement: step 2, image 1 of 1
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      Ask FixBot
    3. Alienware M17x Battery Replacement: step 3, image 1 of 1
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      Ask FixBot
    4. Alienware M17x Battery Replacement: step 4, image 1 of 2 Alienware M17x Battery Replacement: step 4, image 2 of 2
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      Ask FixBot
3 other people completed this guide.
Author
with
Mosier Locke
783 Reputation
5 Guides authored
1 Guide Comment
This is not Alienware M17 R1.
Naveen Nagaraj - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 66
All Time: 3,978
