Up to 20% off select tools
Alienware M17-R1 CPU Cooler Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
71
All Time:
1,401
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The CPU Cooler is one part of the many different components that combine to make this laptop into a fine tuned machine. Double check your part and make sure it is the CPU cooler and not the GPU cooler.
    1. Alienware M17-R1 CPU Cooler Replacement, Battery: step 1, image 1 of 1
      • Push the slider until the battery is released from its socket.
      Ask FixBot
    2. Alienware M17-R1 CPU Cooler Replacement: step 2, image 1 of 1
      • Lift the battery using your fingers.
      • It may be necessary to use a plastic opening tool.
      Ask FixBot
    1. Alienware M17-R1 CPU Cooler Replacement, CPU Cooler: step 3, image 1 of 1
      • First begin by placing the laptop on a hard flat surface.
      • Remove the nine 3 mm screws that secure the back panel using a Phillips #1 screwdriver.
      Ask FixBot
    2. Alienware M17-R1 CPU Cooler Replacement: step 4, image 1 of 1
      • Once the cover has been removed, locate the CPU Cooler to begin the replacement.
      Ask FixBot
    3. Alienware M17-R1 CPU Cooler Replacement: step 5, image 1 of 1
      • Remove the six 7 mm screws using a Phillips #1 and then use the pry tool to unplug the fan before removing the CPU Cooler.
      • Screws 1 through 4 are integrated into the cooler and will come all the way out.
      Ask FixBot
    4. Alienware M17-R1 CPU Cooler Replacement: step 6, image 1 of 1
      • Once all screws have been removed and the cooler has been unplugged, gently lift the cooler out of its compartment to install the new cooling fan.
      Ask FixBot
Author
with
LXA054
337 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 71
All Time: 1,401
