Up to 20% off select tools
Alienware M15x RAM Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
95
All Time:
1,122
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide will explain how to carefully and safely remove the RAM from an Alienware M15x laptop.
    1. Alienware M15x RAM Replacement, Battery: step 1, image 1 of 3 Alienware M15x RAM Replacement, Battery: step 1, image 2 of 3 Alienware M15x RAM Replacement, Battery: step 1, image 3 of 3
      • Remove the battery by sliding the latch to the left and pulling the battery up.
      Ask FixBot
    1. Alienware M15x RAM Replacement, Compartment Door: step 2, image 1 of 2 Alienware M15x RAM Replacement, Compartment Door: step 2, image 2 of 2
      • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
      Ask FixBot
    2. Alienware M15x RAM Replacement: step 3, image 1 of 3 Alienware M15x RAM Replacement: step 3, image 2 of 3 Alienware M15x RAM Replacement: step 3, image 3 of 3
      • Slide the compartment door towards the front of the computer and lift.
      Ask FixBot
    1. Alienware M15x RAM Replacement, RAM: step 4, image 1 of 1
      • Remove the two indicated screws for the RAM cover.
      Ask FixBot
    2. Alienware M15x RAM Replacement: step 5, image 1 of 1
      • Push the two retaining clips on either side of the ram outwards, allowing the RAM chip to pop up.
      Ask FixBot
    3. Alienware M15x RAM Replacement: step 6, image 1 of 1
      • Pull it straight out of its pocket.
      Ask FixBot
    4. Alienware M15x RAM Replacement: step 7, image 1 of 1
      • Repeat the same process if there are additional RAM chips.
      Ask FixBot
Author
with
Aria Saberi
121 Reputation
1 Guide authored
Cal Poly, Team S11-G3, Banghart Winter 2018 Member of Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 95
All Time: 1,122
