Up to 20% off select tools
Alienware M15x Memory Modules Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
59
All Time:
837
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the Memory Modules.
    1. Alienware M15x Memory Modules Replacement, Turn the Computer: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • Turn the computer over.
      Ask FixBot
    2. Alienware M15x Memory Modules Replacement, Sliding the Battery: step 2, image 1 of 1
      • Slide the battery latch to the unlock position as shown.
      Ask FixBot
    3. Alienware M15x Memory Modules Replacement, Removing the Battery Pack: step 3, image 1 of 1
      • After the Battery Pack pops up, remove the Battery Pack.
      Ask FixBot
    4. Alienware M15x Memory Modules Replacement, Aligning the Battery Pack Tabs: step 4, image 1 of 1
      • Align the battery pack tabs with the slots in the battery bay.
      Ask FixBot
    5. Alienware M15x Memory Modules Replacement, Pushing the Battery Pack: step 5, image 1 of 1
      • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
      Ask FixBot
    1. Alienware M15x Memory Modules Replacement, Loosen the Screws: step 6, image 1 of 1
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • Loosen the two captive screws that secure the memory-module door to the computer base.
      Ask FixBot
    2. Alienware M15x Memory Modules Replacement, Lifting the Memory Module Door: step 7, image 1 of 2 Alienware M15x Memory Modules Replacement, Lifting the Memory Module Door: step 7, image 2 of 2
      • Slide the memory-module door to release the tabs and lift the memory-module door out of the computer base.
      Ask FixBot
    3. Alienware M15x Memory Modules Replacement, Popping up the Memory Module: step 8, image 1 of 2 Alienware M15x Memory Modules Replacement, Popping up the Memory Module: step 8, image 2 of 2
      • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
      • CAUTION: To prevent damage to the memory module connector(s), do not use tools to spread the memory module spring-locks.
      • Use your fingertips to carefully spread apart the spring-locks on the memory-module connector until the memory module pops up.
      Ask FixBot
    4. Alienware M15x Memory Modules Replacement, Remove the Memory Module: step 9, image 1 of 1
      • Remove the memory module.
      Ask FixBot
    5. Alienware M15x Memory Modules Replacement, Align the Notch: step 10, image 1 of 3 Alienware M15x Memory Modules Replacement, Align the Notch: step 10, image 2 of 3 Alienware M15x Memory Modules Replacement, Align the Notch: step 10, image 3 of 3
      • Align the notch on the NEW memory module with the tab on the memory-module connector.
      Ask FixBot
    6. Alienware M15x Memory Modules Replacement, Insert the Module: step 11, image 1 of 2 Alienware M15x Memory Modules Replacement, Insert the Module: step 11, image 2 of 2
      • Insert the module into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
      Ask FixBot
    7. Alienware M15x Memory Modules Replacement, Align and Insert the Memory Module Tabs: step 12, image 1 of 2 Alienware M15x Memory Modules Replacement, Align and Insert the Memory Module Tabs: step 12, image 2 of 2
      • CAUTION: If the memory-module door is difficult to close, remove the memory module and reinstall it. Forcing the memory-module door to close may damage your computer.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      • Align and insert the memory-module door tabs into the slots on the computer base.
      Ask FixBot
    8. Alienware M15x Memory Modules Replacement, Replacing and Tightening the Screws: step 13, image 1 of 1
      • Replace and tighten the two captive screws that secure the memory-module door to the computer base.
      Ask FixBot
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 59
All Time: 837
