Alienware M15x Hard-Drive Replacement
    1. Alienware M15x Hard-Drive Replacement, Turn the Computer: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • Turn the computer over.
      Ask FixBot
    2. Alienware M15x Hard-Drive Replacement, Sliding the Battery: step 2, image 1 of 1
      • Slide the battery latch to the unlock position as shown.
      Ask FixBot
    3. Alienware M15x Hard-Drive Replacement, Removing the Battery Pack: step 3, image 1 of 1
      • After the Battery Pack pops up, remove the Battery Pack.
      Ask FixBot
    4. Alienware M15x Hard-Drive Replacement, Aligning the Battery Pack Tabs: step 4, image 1 of 1
      • Align the battery pack tabs with the slots in the battery bay.
      Ask FixBot
    5. Alienware M15x Hard-Drive Replacement, Pushing the Battery Pack: step 5, image 1 of 1
      • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
      Ask FixBot
    1. Alienware M15x Hard-Drive Replacement, Loosen the Screws: step 6, image 1 of 1
      • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
      • Loosen the four captive screws that secure the hard-drive assembly.
      Ask FixBot
    2. Alienware M15x Hard-Drive Replacement, Lifting the Hard-Drive Assembly: step 7, image 1 of 1
      • Using the pull-tab, lift the hard-drive assembly out of the hard-drive bay.
      Ask FixBot
    3. Alienware M15x Hard-Drive Replacement, Remove the Screws: step 8, image 1 of 1
      • Remove the four screws that secure the hard drive to the hard-drive bracket.
      Ask FixBot
    4. Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: step 9, image 1 of 2 Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: step 9, image 2 of 2
      • Lift the hard drive out of the hard-drive bracket.
      Ask FixBot
    5. Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: step 10, image 1 of 2 Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: step 10, image 2 of 2
      • Disconnect the interposer from the hard drive.
      Ask FixBot
    6. Alienware M15x Hard-Drive Replacement, Connecting the Interposer: step 11, image 1 of 2 Alienware M15x Hard-Drive Replacement, Connecting the Interposer: step 11, image 2 of 2
      • Connect the interposer to the NEW hard drive.
      Ask FixBot
    7. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: step 12, image 1 of 2 Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: step 12, image 2 of 2
      • Place the hard drive in the hard-drive bracket.
      Ask FixBot
    8. Alienware M15x Hard-Drive Replacement, Replace the Four Screws: step 13, image 1 of 1
      • Replace the four screws that secure the hard drive to the hard-drive bracket.
      Ask FixBot
    9. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive Assembly: step 14, image 1 of 1
      • Place the hard-drive assembly in the hard-drive bay.
      Ask FixBot
    10. Alienware M15x Hard-Drive Replacement, Aligning and Tightening the Screws: step 15, image 1 of 1
      • Align and tighten the four captive screws that secure the hard-drive assembly to the hard-drive bay.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 61
All Time: 1,010
