Up to 20% off select tools
Alienware M15x GPU Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
125
All Time:
2,713
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Parts
Tools
Introduction
Go to step 1 ↓
If you are experiencing issues playing certain games or frequently see a blue error screen, this might be because the graphics processing unit (GPU) is faulty, meaning it is time to replace it. This guide will help the user replace the GPU on the Alienware M15x laptop. Several steps involve unscrewing tiny screws from the laptop; please ensure that you keep all screws in a secure location as they will be used to rebuild the laptop.
    1. Alienware M15x GPU Replacement, GPU: step 1, image 1 of 1
      • Turn the laptop over so that the bottom is facing upward.
      Ask FixBot
    2. Alienware M15x GPU Replacement: step 2, image 1 of 1
      • Release the battery latch and flip the battery out.
      Ask FixBot
    3. Alienware M15x GPU Replacement: step 3, image 1 of 2 Alienware M15x GPU Replacement: step 3, image 2 of 2
      • Remove the two 4mm screws using a Phillips #1 screwdriver.
      • Remove the compartment door by sliding it away from the battery.
      Ask FixBot
    4. Alienware M15x GPU Replacement: step 4, image 1 of 1
      • Remove the four 4mm screws with the Phillips #1 screwdriver.
      Ask FixBot
    5. Alienware M15x GPU Replacement: step 5, image 1 of 1
      • Position the laptop vertically so that the hinge is facing up and the laptop is slightly open toward the ground
      • The laptop position should resemble an upside-down V shape.
      • Locate the panel and pry open using a plastic opening tool.
      Ask FixBot
    6. Alienware M15x GPU Replacement: step 6, image 1 of 3 Alienware M15x GPU Replacement: step 6, image 2 of 3 Alienware M15x GPU Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Position the laptop normally, with the bottom on the ground and the screen flipped up towards you.
      • Lift the power button panel using the plastic opening tool.
      • Disconnect the ribbon cable by using tweezers to unclip the two small black clips. Remove power button panel.
      Ask FixBot
    7. Alienware M15x GPU Replacement: step 7, image 1 of 1
      • Remove the two 4mm screws with a Phillips #1 screwdriver.
      Ask FixBot
    8. Alienware M15x GPU Replacement: step 8, image 1 of 2 Alienware M15x GPU Replacement: step 8, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the 4mm screw from the exhaust port cover.
      • Remove the exhaust port cover entirely.
      Ask FixBot
    9. Alienware M15x GPU Replacement: step 9, image 1 of 3 Alienware M15x GPU Replacement: step 9, image 2 of 3 Alienware M15x GPU Replacement: step 9, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the two 3mm screws holding the fan in place, then unclip the electrical connection using tweezers.
      Ask FixBot
    10. Alienware M15x GPU Replacement: step 10, image 1 of 1
      • Remove the heat sink by loosening the 4 screws with a Phillips #0 screwdriver.
      Ask FixBot
    11. Alienware M15x GPU Replacement: step 11, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two screws.
      • Remove the GPU from the laptop.
      • When replacing the GPU, it is important to reapply thermal paste in a small line along the length of the chip.
      Ask FixBot
Author
with
Tomas Kronmark
193 Reputation
1 Guide authored
Cal Poly, Team S11-G3, Banghart Winter 2018 Member of Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 125
All Time: 2,713
