Alienware M14xR2 Status-Light Board Replacement
    1. Alienware M14xR2 Status-Light Board Replacement, Battery: step 1, image 1 of 1
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in electric shock and serious injury.
      • Flip the computer upside down.
      Ask FixBot
    2. Alienware M14xR2 Status-Light Board Replacement: step 2, image 1 of 3 Alienware M14xR2 Status-Light Board Replacement: step 2, image 2 of 3 Alienware M14xR2 Status-Light Board Replacement: step 2, image 3 of 3
      • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
      • The two screws are spring loaded and will not separate from the cover.
      • Slide the back cover towards you and then lift upwards to remove.
      Ask FixBot
    3. Alienware M14xR2 Status-Light Board Replacement: step 3, image 1 of 1
      • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
      • The two screws are clipped into the battery and will not detach.
      Ask FixBot
    4. Alienware M14xR2 Status-Light Board Replacement: step 4, image 1 of 3 Alienware M14xR2 Status-Light Board Replacement: step 4, image 2 of 3 Alienware M14xR2 Status-Light Board Replacement: step 4, image 3 of 3
      • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
      • Pull up on the white connector to disconnect it from the laptop.
      • The battery is now free to remove from the laptop and can be set aside.
      Ask FixBot
    1. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: step 5, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
      • Turn the palm-rest assembly over.
      Ask FixBot
    2. Alienware M14xR2 Status-Light Board Replacement, Remove the Cable: step 6, image 1 of 1
      • Note the routing of status-light board cable and remove the cable from the routing guides.
      • NOTE: If the status-light board cable is under the speakers cable, remove the speakers cable first and then remove the status-light board cable.
      Ask FixBot
    3. Alienware M14xR2 Status-Light Board Replacement, Turn the Palm-Rest Assembly Over: step 7, image 1 of 1
      Ask FixBot
    4. Alienware M14xR2 Status-Light Board Replacement, Remove the Screw: step 8, image 1 of 1
      • Remove the screw that secures the status-light board to the palm-rest assembly.
      Ask FixBot
    5. Alienware M14xR2 Status-Light Board Replacement, Lifting the Status-Light Board: step 9, image 1 of 1
      • Carefully lift the status-light board and release its cable from the slot on the palm-rest assembly.
      Ask FixBot
    6. Alienware M14xR2 Status-Light Board Replacement, Slide the Status-Light Board Cable: step 10, image 1 of 1
      • Slide the NEW status-light board cable through the slot in the palm-rest assembly.
      Ask FixBot
    7. Alienware M14xR2 Status-Light Board Replacement, Align the Slot: step 11, image 1 of 1
      • Align the slot on the status-light board with the alignment post on the palm-rest assembly.
      Ask FixBot
    8. Alienware M14xR2 Status-Light Board Replacement, Replace the Screw: step 12, image 1 of 1
      • Replace the screw that secures the status-light board to the palm-rest assembly.
      Ask FixBot
    9. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: step 13, image 1 of 1
      Ask FixBot
    10. Alienware M14xR2 Status-Light Board Replacement, Routing the Status-Light Board Cable: step 14, image 1 of 1
      • Route the status-light board cable through the routing guides on the palm-rest assembly.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
1 Guide Comment
Völliges Durcheinander und unvollständig
Robert Fleischhauer - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 76
All Time: 1,275
