Up to 20% off select tools
Alienware M14xR2 RAM Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
9
Past 7 Days:
33
Past 30 Days:
107
All Time:
3,069
Comments: 3
3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to safely access and replace the RAM sticks for the Alienware M14xR2 laptop. In order to remove the RAM you need to first remove the battery and the CD drive.
    1. Alienware M14xR2 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in electric shock and serious injury.
      • Flip the computer upside down.
      Ask FixBot
    2. Alienware M14xR2 RAM Replacement: step 2, image 1 of 3 Alienware M14xR2 RAM Replacement: step 2, image 2 of 3 Alienware M14xR2 RAM Replacement: step 2, image 3 of 3
      • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
      • The two screws are spring loaded and will not separate from the cover.
      • Slide the back cover towards you and then lift upwards to remove.
      Ask FixBot
    3. Alienware M14xR2 RAM Replacement: step 3, image 1 of 1
      • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
      • The two screws are clipped into the battery and will not detach.
      Ask FixBot
    4. Alienware M14xR2 RAM Replacement: step 4, image 1 of 3 Alienware M14xR2 RAM Replacement: step 4, image 2 of 3 Alienware M14xR2 RAM Replacement: step 4, image 3 of 3
      • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
      • Pull up on the white connector to disconnect it from the laptop.
      • The battery is now free to remove from the laptop and can be set aside.
      Ask FixBot
    1. Alienware M14xR2 RAM Replacement, Optical Drive: step 5, image 1 of 3 Alienware M14xR2 RAM Replacement, Optical Drive: step 5, image 2 of 3 Alienware M14xR2 RAM Replacement, Optical Drive: step 5, image 3 of 3
      • Unscrew the four 6.35 mm size 1 screws.
      • Pull up on the end of the orange tab to detach it from the white connector.
      • Lift the optical drive up and out of the laptop and set it aside.
      Ask FixBot
    1. Alienware M14xR2 RAM Replacement, RAM: step 6, image 1 of 3 Alienware M14xR2 RAM Replacement, RAM: step 6, image 2 of 3 Alienware M14xR2 RAM Replacement, RAM: step 6, image 3 of 3
      • Unscrew the two 6.35 mm size 1 screws.
      • Lift up and remove the panel covering the RAM sticks.
      Ask FixBot
    2. Alienware M14xR2 RAM Replacement: step 7, image 1 of 2 Alienware M14xR2 RAM Replacement: step 7, image 2 of 2
      • Push outward on both prongs that secure the RAM sticks in place.
      • The RAM sticks will rise upward when released from the prongs.
      Ask FixBot
    3. Alienware M14xR2 RAM Replacement: step 8, image 1 of 2 Alienware M14xR2 RAM Replacement: step 8, image 2 of 2
      • Grab and pull the RAM sticks up and out of their casing and set them aside.
      Ask FixBot
4 other people completed this guide.
Author
with
Eugene Park
195 Reputation
1 Guide authored
Cal Poly, Team 13-4, Forte Fall 2013 Member of Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Members
60 Guides authored
3 Guide Comments
How max is the ram upgrade compatible with the m14x ifixit?!
doantuan85 - Reply Share
I meaned r1 model
Yo, man! If my RAM slot is damaged somehow, is there any possibility to change/repair it? It won't detect a RAM card, keeps beeping 4 times at the start.
tasanov - Reply Share
Past 24 Hours: 9
Past 7 Days: 33
Past 30 Days: 107
All Time: 3,069
