Introduction
Go to step 1 ↓This guide will show you how to safely remove the optical drive from the laptop. In order to remove the optical drive you first need to remove the battery.
Turn the computer off.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Unscrew the four 6.35 mm size 1 screws.
Pull up on the end of the orange tab to detach it from the white connector.
Lift the optical drive up and out of the laptop and set it aside.
