Up to 20% off select tools
Alienware M14xR2 Battery Replacement
Views: 12K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
109
All Time:
11,965
Comments: 0
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to safely remove your laptop battery without damaging the laptop or battery.
    1. Alienware M14xR2 Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in electric shock and serious injury.
      • Flip the computer upside down.
      Ask FixBot
    2. Alienware M14xR2 Battery Replacement: step 2, image 1 of 3 Alienware M14xR2 Battery Replacement: step 2, image 2 of 3 Alienware M14xR2 Battery Replacement: step 2, image 3 of 3
      • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
      • The two screws are spring loaded and will not separate from the cover.
      • Slide the back cover towards you and then lift upwards to remove.
      Ask FixBot
    3. Alienware M14xR2 Battery Replacement: step 3, image 1 of 1
      • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
      • The two screws are clipped into the battery and will not detach.
      Ask FixBot
    4. Alienware M14xR2 Battery Replacement: step 4, image 1 of 3 Alienware M14xR2 Battery Replacement: step 4, image 2 of 3 Alienware M14xR2 Battery Replacement: step 4, image 3 of 3
      • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
      • Pull up on the white connector to disconnect it from the laptop.
      • The battery is now free to remove from the laptop and can be set aside.
      Ask FixBot
10 other people completed this guide.
Author
with
Connor Bovee
569 Reputation
2 Guides authored
Cal Poly, Team 13-4, Forte Fall 2013 Member of Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 109
All Time: 11,965
