Alienware M11xR3 Disassembly and Cleaning
Views: 27K
View statistics:
Past 24 Hours:
3
Past 7 Days:
36
Past 30 Days:
147
All Time:
26,755
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 24
24 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes - 2 hours
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Introduction
Go to step 1 ↓
Here you can fix common problems like keyboard replacement, dirty vents, and thermal paste replacement.
I am not responsible for damages that may be caused. This is for informational purposes only. Follow at your own risk.
This is my first guide so please be kind.
Tools
    1. Alienware M11xR3 Disassembly and Cleaning, Beginning (Parts, Tools and Laptop): step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Welcome to the Alienware M11xR3 disassembly. Below, I will describe the necessary tools and steps to disassemble the Alienware M11xR3. This disassembly applies to all M11x, including the R1, R2, and R3.
      • Required tools:
      • 1x Phillips #1 and #00 Screwdriver
      • 1x Flathead Screwdriver
      • 1x Small Needle Nose Pliers or Tweezers
      • 1x Thermal Paste and Finger Stalls Optional: Small water balloons (to spread thermal paste without getting dirty)
      • 1x Anti-Static Mat
      • I highly recommended reading about static electricity and how it can damage electronic components.
      Ask FixBot
    2. Alienware M11xR3 Disassembly and Cleaning, Remove back plate screws.: step 2, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning, Remove back plate screws.: step 2, image 2 of 2
      • Gently flip over the laptop so that the bottom side is facing up.
      • Use a Phillips #1 screwdriver to remove the 8 screws securing the base-plate.
      Ask FixBot
    3. Alienware M11xR3 Disassembly and Cleaning, Remove back plate.: step 3, image 1 of 1
      • Lift the bottom cover and remove it.
      Ask FixBot
    4. Alienware M11xR3 Disassembly and Cleaning, Unscrew and unplug battery.: step 4, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Unscrew and unplug battery.: step 4, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Unscrew and unplug battery.: step 4, image 3 of 3
      • Remove the battery cable on the plate by pulling vertically.
      • Unscrew and remove the screws retaining the battery.
      Ask FixBot
    5. Alienware M11xR3 Disassembly and Cleaning, Remove Battery.: step 5, image 1 of 1
      • Remove the battery.
      Ask FixBot
    6. Alienware M11xR3 Disassembly and Cleaning, Remove the HDD: step 6, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning, Remove the HDD: step 6, image 2 of 2
      • Remove the hard drive mounting bracket by removing the three screws with the Phillips #1 screwdriver.
      • Pull out the hard drive by lifting up on the black tab.
      Ask FixBot
    7. Alienware M11xR3 Disassembly and Cleaning, (Optional) Replace HDD: step 7, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, (Optional) Replace HDD: step 7, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, (Optional) Replace HDD: step 7, image 3 of 3
      • In order to remove the hard drive from the mounting bracket, remove the four screws at each corner with the Phillips #1 screwdriver.
      • When installing a new hard drive, never forget to remove the SATA adapter before installation.
      Ask FixBot
    8. Alienware M11xR3 Disassembly and Cleaning, Remove RAM: step 8, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove RAM: step 8, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove RAM: step 8, image 3 of 3
      • Pull the tabs away from RAM.
      • Carefully pull the RAM module to remove.
      • Depending on the configuration that you have on your Alienware, there may be another RAM module.
      • If you want to upgrade your RAM please read the manual about which modules are compatible. Here are the RAM specs:
      • Number of Sockets: 2
      • Max memory: 16384 MB (16GB)
      • Memory Comments: PC3-10600 1333Mhz DDR3 SDRAM SO-DIMM 204-pin
      Ask FixBot
    9. Alienware M11xR3 Disassembly and Cleaning, Remove WLAN module: step 9, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove WLAN module: step 9, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove WLAN module: step 9, image 3 of 3
      • Depending on your Alienware configuration, it can have up to 3 aerial cables.
      • Remove the aerial cables vertically with Tweezers or Small Needle Nose Pliers.
      • Once the aerial cables are removed, extract the screws.
      • Remove the WLAN card.
      • On USA models, a WWAN card may be located near the WLAN card. Use the same process to remove it.
      Ask FixBot
    10. Alienware M11xR3 Disassembly and Cleaning, Remove chassis and keyboard screws: step 10, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove chassis and keyboard screws: step 10, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove chassis and keyboard screws: step 10, image 3 of 3
      • Remove the chassis screws using a Phillips #1 screwdriver.
      • Remove the keyboard screws using a Phillips #1 screwdriver.
      Ask FixBot
    11. Alienware M11xR3 Disassembly and Cleaning, Remove the chassis screws: step 11, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove the chassis screws: step 11, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove the chassis screws: step 11, image 3 of 3
      • Remove the chassis screws.
      Ask FixBot
    12. Alienware M11xR3 Disassembly and Cleaning, Remove the bottom chassis screws: step 12, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning, Remove the bottom chassis screws: step 12, image 2 of 2
      • Remove the bottom chassis screws.
      Ask FixBot
    13. Alienware M11xR3 Disassembly and Cleaning: step 13, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning: step 13, image 2 of 2
      • The screw marked with a yellow circle is near the hard drive bay.
      Ask FixBot
    14. Alienware M11xR3 Disassembly and Cleaning, Remove the screws from the keyboard: step 14, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning, Remove the screws from the keyboard: step 14, image 2 of 2
      • Remove the screws from the keyboard.
      Ask FixBot
    15. Alienware M11xR3 Disassembly and Cleaning, Remove the cover: step 15, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove the cover: step 15, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove the cover: step 15, image 3 of 3
      • Use a small flat screwdriver to carefully pry the cover from the chassis.
      • Next, use your finger as a lever to extract the cover. The cover has tabs that attach it to the chassis.
      • In the next step, I'll show you tab locations.
      Ask FixBot
    16. Alienware M11xR3 Disassembly and Cleaning, Tab locations: step 16, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Tab locations: step 16, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Tab locations: step 16, image 3 of 3
      • Clamping tabs
      Ask FixBot
    17. Alienware M11xR3 Disassembly and Cleaning: step 17, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning: step 17, image 2 of 2
      • Remove the two screws to release the keyboard.
      • Wait for the next step to remove the keyboard; there are bus data cables underneath the keyboard that must be removed first.
      Ask FixBot
    18. Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 1): step 18, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 1): step 18, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 1): step 18, image 3 of 3
      • There are 2 bus data cables.
      • The thin orange cable is the RGB led keyboard retro illumination.
      • Lift the tab to a vertical position to free the bus cable as shown.
      Ask FixBot
    19. Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 2): step 19, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 2): step 19, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 2): step 19, image 3 of 3
      • Free the keyboard bus data cable as you did for the RGB bus data cable.
      • Remove the keyboard to replace it; it has pressure points like the previous cover.
      • If the keyboard fails, the best option is to replace it for a new one.
      Ask FixBot
    20. Alienware M11xR3 Disassembly and Cleaning, Remove more chassis screws: step 20, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove more chassis screws: step 20, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove more chassis screws: step 20, image 3 of 3
      • Continue taking out the chassis by unscrewing the 3 shown screws.
      • First one to the left of the RGB bus data cable.
      • Second one at bottom near the touchpad.
      • Third one on the right edge of the laptop.
      Ask FixBot
    21. Alienware M11xR3 Disassembly and Cleaning, Remove touchpad data bus cable: step 21, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove touchpad data bus cable: step 21, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove touchpad data bus cable: step 21, image 3 of 3
      • Lift the tab to disconnect the touchpad data bus cable.
      Ask FixBot
    22. Alienware M11xR3 Disassembly and Cleaning, Remove bus cable to Motherboard.: step 22, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus cable to Motherboard.: step 22, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus cable to Motherboard.: step 22, image 3 of 3
      • Extract the bus cable with needle nose pliers by lifting the tab and pulling it away.
      • If your computer doesn't power on, then check to make sure this cable is plugged in.
      • Always lift tabs vertically to free cables.
      Ask FixBot
    23. Alienware M11xR3 Disassembly and Cleaning: step 23, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning: step 23, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning: step 23, image 3 of 3
      • Lift the case with your fingers, as shown in the pictures.
      • Don't remove the case yet. There is another cable on the upper left corner that must be removed to fully remove the case.
      Ask FixBot
    24. Alienware M11xR3 Disassembly and Cleaning: step 24, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning: step 24, image 2 of 2
      • This is the cable that I mentioned in the previous step.
      • Pull the cable out to the right to remove it.
      Ask FixBot
    25. Alienware M11xR3 Disassembly and Cleaning: step 25, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning: step 25, image 2 of 2
      • Here's a top and bottom view of the board with the power on switch and LED status.
      Ask FixBot
    26. Alienware M11xR3 Disassembly and Cleaning: step 26, image 1 of 1
      • And here's a bottom view of the touchpad.
      Ask FixBot
    27. Alienware M11xR3 Disassembly and Cleaning, Removing the bluetooth card.: step 27, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning, Removing the bluetooth card.: step 27, image 2 of 2
      • Remove the shown screw.
      • Pull the cable off.
      Ask FixBot
    28. Alienware M11xR3 Disassembly and Cleaning, (Optional)  Remove the BIOS battery: step 28, image 1 of 1
      • This is the BIOS battery for internal configuration and clock. If you have problems with it, remove it by disconnecting it from the motherboard.
      Ask FixBot
    29. Alienware M11xR3 Disassembly and Cleaning: step 29, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning: step 29, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning: step 29, image 3 of 3
      • Pull the speakers connector towards you and away from the I/O board, marked by a yellow square.
      • Remove the 3 screws and lift as you see in the picture
      • Move the board a little to the left while lifting to prevent damaging the two attached USB 3.0 ports.
      Ask FixBot
    30. Alienware M11xR3 Disassembly and Cleaning, Removing the display connector.: step 30, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Removing the display connector.: step 30, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Removing the display connector.: step 30, image 3 of 3
      • Remove the display connector by pulling vertically.
      • Lift using the plastic tab. See the image provided in this step.
      Ask FixBot
    31. Alienware M11xR3 Disassembly and Cleaning, Removing the monitor mount: step 31, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Removing the monitor mount: step 31, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Removing the monitor mount: step 31, image 3 of 3
      • Unscrew the screws in the correct order by using the numbers near the holes.
      • Make sure you are holding the monitor while unscrewing to prevent dropping and damaging the screen.
      • After that, you must see the next step to remove the WLAN aerials.
      Ask FixBot
    32. Alienware M11xR3 Disassembly and Cleaning, Pull WLAN cable away with monitor: step 32, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning, Pull WLAN cable away with monitor: step 32, image 2 of 2
      • The WLAN cable is the same as in step 9.
      • Pass the cable from the bottom of the laptop through the hole carefully.
      • Remember, depending on your Alienware configuration you may have 2 or 3 aerials. USA customers may also have the WWAN aerials
      Ask FixBot
    33. Alienware M11xR3 Disassembly and Cleaning, Removing the motherboard.: step 33, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Removing the motherboard.: step 33, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Removing the motherboard.: step 33, image 3 of 3
      • Remove the four screws, marked by red circles, to remove the motherboard.
      • Now lift the motherboard slowly up while moving it to the right. Removing it this way prevents damage to your ports.
      • As you see in the picture, the I/O board and screen connector wasn't here. They must be disconnected before removing the motherboard, not like the bluetooth board or coin-cell battery.
      Ask FixBot
    34. Alienware M11xR3 Disassembly and Cleaning: step 34, image 1 of 2 Alienware M11xR3 Disassembly and Cleaning: step 34, image 2 of 2
      • Disconnect the vent connector.
      • You must disconnect it to remove the heatsink.
      • To replace the vent, it is not necessary to remove the heatsink. You must do this step and in the next step I have marked in green the 3 screws that you need to remove.
      • To maintain good ventilation, clean the vent with compressed air.
      Ask FixBot
    35. Alienware M11xR3 Disassembly and Cleaning, Remove heat sink and apply thermal paste: step 35, image 1 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove heat sink and apply thermal paste: step 35, image 2 of 3 Alienware M11xR3 Disassembly and Cleaning, Remove heat sink and apply thermal paste: step 35, image 3 of 3
      • If this is your first time applying thermal paste, I recommend using a quality thermal paste brand like Arctic Silver and reading a guide here on iFixit.
      • With the motherboard out, turn it upside down on a static free surface.
      • To remove the heatsink and replace thermal paste, remove the screws in the correct order (marked with a number on the heatsink).
      • Clean old thermal paste with isopropyl alcohol. Ensure that after applying thermal paste it doesn't leak onto the motherboard (if it's on the green square, it's fine).
      • When putting the heat sink back on, try to have the screw holes align on your first try. This is to maintain an even spread of the thermal paste.
      • Rescrew in the correct order (refer to the numbers on the heat sink).
      • Tighten each screw one at a time to end up with good heat dissipation.
      Ask FixBot
Finish Line
7 other people completed this guide.
AdrianP
442 Reputation
1 Guide authored
3 Guide Comments
I needed to modify it so i t would work for my M11X R1
but after all, pretty goosd tutorial.
Szymon PlayZGameZ - Reply Share
Awesomely detailed, thank you :)
fraser - Reply Share
excellent post for servicing the M11. yes 14 years on and still working.
Amateur Hour - Reply Share
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 147
All Time: 26,755
