Up to 20% off select tools
Alienware M11xR2 Display Assembly Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
55
All Time:
1,251
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 25 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
How to remove and replace the Display Assembly.
    1. Alienware M11xR2 Display Assembly Replacement, Disconnecting Antenna Cable: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Disconnect the antenna cables from the Mini-Card(s).
      Ask FixBot
    2. Alienware M11xR2 Display Assembly Replacement, Removing Mimi Card: step 2, image 1 of 1
      • The routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
      Ask FixBot
    3. Alienware M11xR2 Display Assembly Replacement, Turning Over The Computer: step 3, image 1 of 1
      • Turn the computer over and open the display as far as possible.
      Ask FixBot
    4. Alienware M11xR2 Display Assembly Replacement, Pulling The Pull-Tab: step 4, image 1 of 1
      • Pull the pull-tab to disconnect the display cable from the connector on the system board.
      Ask FixBot
    5. Alienware M11xR2 Display Assembly Replacement, Removing Screws: step 5, image 1 of 1
      • Remove the four screws that secure the display assembly to the computer base.
      Ask FixBot
    6. Alienware M11xR2 Display Assembly Replacement, Removing Mini-Card cable: step 6, image 1 of 1
      • Gently slide the Mini-Card antenna cables out through the slot on the computer base.
      Ask FixBot
    7. Alienware M11xR2 Display Assembly Replacement, Lifting Display Assembly: step 7, image 1 of 1
      • Lift the display assembly off the computer.
      Ask FixBot
    8. Alienware M11xR2 Display Assembly Replacement, Sliding New Cables: step 8, image 1 of 1
      • Slide the antenna cables in through the slot on the computer base.
      Ask FixBot
    9. Alienware M11xR2 Display Assembly Replacement, Securing Screws: step 9, image 1 of 1
      • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
      Ask FixBot
    10. Alienware M11xR2 Display Assembly Replacement, Connecting New Display Cable: step 10, image 1 of 1
      • Connect the display cable to the connector on the system board.
      Ask FixBot
    11. Alienware M11xR2 Display Assembly Replacement, Rerouting  The Mini-Card Cable: step 11, image 1 of 1
      • Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
      Ask FixBot
    12. Alienware M11xR2 Display Assembly Replacement, Connecting Mini-Card Cables: step 12, image 1 of 1
      • Connect the Mini-Card antenna cables to the Mini-Card(s).
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 55
All Time: 1,251
