Alienware M11xR2 Coin-Cell Battery Replacement
    1. Alienware M11xR2 Coin-Cell Battery Replacement, Removing the Base Cover: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Turn the computer over.
      Ask FixBot
    2. Alienware M11xR2 Coin-Cell Battery Replacement, Loosen the Screws: step 2, image 1 of 1
      • Loosen the eight captive screws that secure the base cover to the computer base.
      Ask FixBot
    3. Alienware M11xR2 Coin-Cell Battery Replacement, Lifting the Base Cover: step 3, image 1 of 1
      • Lift the base cover off the computer base.
      Ask FixBot
    4. Alienware M11xR2 Coin-Cell Battery Replacement, Replacing the Base Cover: step 4, image 1 of 1
      • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
      Ask FixBot
    5. Alienware M11xR2 Coin-Cell Battery Replacement, Securing the Screws: step 5, image 1 of 1
      • Tighten the eight screws that secure the base cover to the computer base.
      Ask FixBot
    1. Alienware M11xR2 Coin-Cell Battery Replacement, Disconnecting Coin-Cell Battery: step 6, image 1 of 1
      • Disconnect the coin-cell battery cable from the connector on the system board.
      Ask FixBot
    2. Alienware M11xR2 Coin-Cell Battery Replacement, Prying The Coin-Cell Battery: step 7, image 1 of 1
      • The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
      Ask FixBot
    3. Alienware M11xR2 Coin-Cell Battery Replacement, Placing New Coin-Cell Battery: step 8, image 1 of 1
      • Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
      Ask FixBot
    4. Alienware M11xR2 Coin-Cell Battery Replacement, Connecting Cable: step 9, image 1 of 1
      • Connect the coin-cell battery cable to the connector on the system board.
      Ask FixBot
3 other people completed this guide.
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 69
All Time: 1,240
