Up to 20% off select tools
Alienware M11x Memory Module Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
53
All Time:
1,013
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Module.
    1. Alienware M11x Memory Module Replacement, Introduction: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      Ask FixBot
    2. Alienware M11x Memory Module Replacement, Removing the Memory Module: step 2, image 1 of 1
      • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      Ask FixBot
    3. Alienware M11x Memory Module Replacement, Removing the Memory Module: step 3, image 1 of 2 Alienware M11x Memory Module Replacement, Removing the Memory Module: step 3, image 2 of 2
      • Remove the memory module from the memory module connector.
      Ask FixBot
    4. Alienware M11x Memory Module Replacement, Replacing the Memory Module: step 4, image 1 of 1
      • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
      • Align the notch in the NEW memory module with the tab in the memory module connector.
      Ask FixBot
    5. Alienware M11x Memory Module Replacement, Installing the Memory Module: step 5, image 1 of 1
      • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 53
All Time: 1,013
