Up to 20% off select tools
Alienware M11x Display Assembly Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
60
All Time:
1,331
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Display Assembly.
    1. Alienware M11x Display Assembly Replacement, Introduction: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • NOTE: Dell or Alienware does not guarantee compatibility or provide support for hard drives from sources other than Dell.
      • NOTE: If you are installing a hard drive from a source other than Dell or Alienware, you need to install an operating system, drivers, and utilities on the new hard drive.
      Ask FixBot
    2. Alienware M11x Display Assembly Replacement, Loosen the Screws: step 2, image 1 of 1
      • Loosen the two captive screws that secure the hard-drive assembly to the computer base.
      Ask FixBot
    3. Alienware M11x Display Assembly Replacement, Disconnecting the Hard-Drive: step 3, image 1 of 1
      • Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
      Ask FixBot
    4. Alienware M11x Display Assembly Replacement, Lifting the Hard-Drive Assembly: step 4, image 1 of 1
      • Lift the hard-drive assembly out of the computer base.
      Ask FixBot
    5. Alienware M11x Display Assembly Replacement, Removing the Screws from the Hard-Drive: step 5, image 1 of 1
      • Remove the four screws that secure the hard drive to the hard-drive bracket.
      Ask FixBot
    6. Alienware M11x Display Assembly Replacement, Removing the Bracket: step 6, image 1 of 1
      • Lift the hard drive away from the hard-drive bracket.
      Ask FixBot
    7. Alienware M11x Display Assembly Replacement, Placing the Hard-Drive: step 7, image 1 of 1
      • Place the NEW hard drive in the hard-drive bracket.
      Ask FixBot
    8. Alienware M11x Display Assembly Replacement, Replace the Screws: step 8, image 1 of 1
      • Replace the four screws that secure the hard-drive to the hard-drive bracket.
      Ask FixBot
    9. Alienware M11x Display Assembly Replacement, Placing the Hard-Drive: step 9, image 1 of 1
      • Place the hard-drive assembly in the computer base.
      Ask FixBot
    10. Alienware M11x Display Assembly Replacement, Connecting the Hard-Drive Assembly: step 10, image 1 of 1
      • Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
      Ask FixBot
    11. Alienware M11x Display Assembly Replacement, Securing the Screws: step 11, image 1 of 1
      • Tighten the two captive screws that secure the hard-drive assembly to the computer base.
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 60
All Time: 1,331
