Alienware Aurora M9700 RAM Replacement
    1. Alienware Aurora M9700 RAM Replacement, RAM: step 1, image 1 of 1
      • Turn the laptop over so the bottom of the device is facing upward.
      Ask FixBot
    2. Alienware Aurora M9700 RAM Replacement: step 2, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 2, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 2, image 3 of 3
      • Remove the battery by unlocking the lock.
      Ask FixBot
    3. Alienware Aurora M9700 RAM Replacement: step 3, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 3, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 3, image 3 of 3
      • Located on the top right corner, find the 4 screws that are holding the back plate to the laptop.
      • Once the screws are removed insert the spudger on the right side and pry upwards to lift the plate to remove the plate.
      Ask FixBot
    4. Alienware Aurora M9700 RAM Replacement: step 4, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 4, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 4, image 3 of 3
      • Lift the back plate of the laptop to expose the RAM.
      • Locate the RAM near the bottom edge of the top portion.
      Ask FixBot
    5. Alienware Aurora M9700 RAM Replacement: step 5, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 5, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 5, image 3 of 3
      • The RAM is secured by two aluminum locks on each side.
      • Pull the left-lock to the left to release the RAM.
      • While still holding the left hinge, pull the right-lock to the right and the RAM will be released.
      Ask FixBot
    6. Alienware Aurora M9700 RAM Replacement: step 6, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 6, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 6, image 3 of 3
      • Once the RAM is released, pull the RAM out.
      • There may be a second RAM located below the first one, if so repeat step 5.
      • After both RAMS are removed you can now replace or upgrade the RAM.
      Ask FixBot
Jasmine Anchondo
679 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 55
All Time: 668
