Alienware Aurora M9700 Hard Drive Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
56
All Time:
771
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide provides instructions on how to upgrade or replace the hard drive in an Alienware Aurora M9700.
    1. Alienware Aurora M9700 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Turn laptop upside down so you're looking at the bottom side of the laptop.
      Ask FixBot
    2. Alienware Aurora M9700 Hard Drive Replacement: step 2, image 1 of 3 Alienware Aurora M9700 Hard Drive Replacement: step 2, image 2 of 3 Alienware Aurora M9700 Hard Drive Replacement: step 2, image 3 of 3
      • At the bottom left corner, locate the square battery pack with the sliding unlock emblem above it.
      • Slide the lock to the right to unlock the battery pack.
      • Once it's unlocked the battery will release.
      • Lift the battery, removing it from its compartment.
      Ask FixBot
    3. Alienware Aurora M9700 Hard Drive Replacement: step 3, image 1 of 3 Alienware Aurora M9700 Hard Drive Replacement: step 3, image 2 of 3 Alienware Aurora M9700 Hard Drive Replacement: step 3, image 3 of 3
      • At the bottom right corner, locate the two hard drives labeled 1 and 2.
      • Remove the screws located on top of the hard drives slots.
      • Once screws are removed from each hard drive, slide both hard drives out of the slot.
      Ask FixBot
    4. Alienware Aurora M9700 Hard Drive Replacement: step 4, image 1 of 3 Alienware Aurora M9700 Hard Drive Replacement: step 4, image 2 of 3 Alienware Aurora M9700 Hard Drive Replacement: step 4, image 3 of 3
      • Each hard drive is attached to a cover which contains 4 screws located on all 4 corners of the hard drive.
      • Remove each of the 4 screws on both hard drive covers.
      • Once both covers are removed only the original hard drive will remain.
      Ask FixBot
    5. Alienware Aurora M9700 Hard Drive Replacement: step 5, image 1 of 3 Alienware Aurora M9700 Hard Drive Replacement: step 5, image 2 of 3 Alienware Aurora M9700 Hard Drive Replacement: step 5, image 3 of 3
      • Secure the new hard drive to the original hard drive cover, insert the screws on all 4 corners of the hard drive cover.
      • Complete this process for both hard drives. (Optional: if installing two drives.)
      Ask FixBot
Jasmine Anchondo
679 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 56
All Time: 771
