Alienware Aurora M9700 Camera Replacement
    1. Alienware Aurora M9700 Camera Replacement, Camera: step 1, image 1 of 1
      • Open the device so the main screen is facing forward.
      • Locate the 8 rubber buttons around the bezel of the display and remove the rubber buttons with the metal spudger to expose the screws underneath.
      • Locate the 8 screws around the perimeter of the screen and unscrew them.
      Ask FixBot
    2. Alienware Aurora M9700 Camera Replacement: step 2, image 1 of 2 Alienware Aurora M9700 Camera Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool between the black and green frames to remove the display frame at the bottom of the display.
      • Slide the lock to the right when removing the display frame.
      • Remove the frame display.
      Ask FixBot
    3. Alienware Aurora M9700 Camera Replacement: step 3, image 1 of 2 Alienware Aurora M9700 Camera Replacement: step 3, image 2 of 2
      • Now that the outer frame is removed, locate the two screws to the right and the left of the camera.
      • Remove the two screws freeing the camera of the brackets holding it in place.
      • Pry the camera upward from its designated location using the metal spudger.
      Ask FixBot
    4. Alienware Aurora M9700 Camera Replacement: step 4, image 1 of 2 Alienware Aurora M9700 Camera Replacement: step 4, image 2 of 2
      • Unplug the wire connection between the camera and the laptop.
      Ask FixBot
Jasmine Anchondo
679 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 55
All Time: 501
