Up to 20% off select tools
Alienware Area-51m Battery Replacement
Views: 3K
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
29
All Time:
2,965
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to replace the battery on your Alienware Area-51m. However, this guide is only for the person who have strong hands-on ability. If you think you cannot handle this work please find professional repair company. We are not responsible for any mistake or damage when you try to repair your computer.
    1. Alienware Area-51m Battery Replacement, Battery: step 1, image 1 of 3 Alienware Area-51m Battery Replacement, Battery: step 1, image 2 of 3 Alienware Area-51m Battery Replacement, Battery: step 1, image 3 of 3
      • Turn off the laptop and remove all the cables connected to your laptop.
      • Place the back of the laptop up.
      • Remove the six 8mm screws from the back cover using a Phillips #0 screwdriver.
      Ask FixBot
    2. Alienware Area-51m Battery Replacement: step 2, image 1 of 3 Alienware Area-51m Battery Replacement: step 2, image 2 of 3 Alienware Area-51m Battery Replacement: step 2, image 3 of 3
      • Remove the battery cable from the motherboard.
      • Remove the six 5 mm screws holding down the battery using a Phillips #0 screwdriver.
      • Insert translation here
      Ask FixBot
    3. Alienware Area-51m Battery Replacement: step 3, image 1 of 2 Alienware Area-51m Battery Replacement: step 3, image 2 of 2
      • Lift the battery out of the case.
      Ask FixBot
    4. Alienware Area-51m Battery Replacement: step 4, image 1 of 3 Alienware Area-51m Battery Replacement: step 4, image 2 of 3 Alienware Area-51m Battery Replacement: step 4, image 3 of 3
      • Put the new battery back and connect the battery cable to the motherboard.
      • Replace the six 5mm screws using a Phillips #0 screwdriver.
      Ask FixBot
When reassembling your device, follow the instructions in reverse order.
Special thanks to these translators:
zh en
100%
Austin Blakely is helping us fix the world! Want to contribute?
Start translating ›
Author
with
yupeng ge
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 29
All Time: 2,965
