Alienware AW610M USB-C Charging Port Replacement
  1. Alienware AW610M USB-C Charging Port Replacement, Battery: step 1, image 1 of 3 Alienware AW610M USB-C Charging Port Replacement, Battery: step 1, image 2 of 3 Alienware AW610M USB-C Charging Port Replacement, Battery: step 1, image 3 of 3
    • Power off the mouse and disconnect any wired connections.
    Ask FixBot
  2. Alienware AW610M USB-C Charging Port Replacement: step 2, image 1 of 2 Alienware AW610M USB-C Charging Port Replacement: step 2, image 2 of 2
    • Use a spudger to gently lift and remove the old mouse feet.
    • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
    • Be careful not to scratch the mouse surface or damage the plastic housing.
    Ask FixBot
  3. Alienware AW610M USB-C Charging Port Replacement: step 3, image 1 of 2 Alienware AW610M USB-C Charging Port Replacement: step 3, image 2 of 2
    • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
    Ask FixBot
  4. Alienware AW610M USB-C Charging Port Replacement: step 4, image 1 of 2 Alienware AW610M USB-C Charging Port Replacement: step 4, image 2 of 2
    • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
    • Don't pull the halves completely apart, as internal wires still connect them.
    Ask FixBot
  5. Alienware AW610M USB-C Charging Port Replacement: step 5, image 1 of 3 Alienware AW610M USB-C Charging Port Replacement: step 5, image 2 of 3 Alienware AW610M USB-C Charging Port Replacement: step 5, image 3 of 3
    • Remove the battery pack inside the mouse.
    • If you are having trouble, use a small flat tool to help ease it out.
    • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
    Ask FixBot
  6. Alienware AW610M USB-C Charging Port Replacement: step 6, image 1 of 2 Alienware AW610M USB-C Charging Port Replacement: step 6, image 2 of 2
    • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
    • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
    Ask FixBot
  7. Alienware AW610M USB-C Charging Port Replacement, Motherboard: step 7, image 1 of 2 Alienware AW610M USB-C Charging Port Replacement, Motherboard: step 7, image 2 of 2
    • Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
    • Detach the cable connector, and remove the scroll wheel.
    • Gently detach the last connector using your fingers.
    • Be careful when unplugging all connectors to prevent tearing them.
    Ask FixBot
  8. Alienware AW610M USB-C Charging Port Replacement: step 8, image 1 of 2 Alienware AW610M USB-C Charging Port Replacement: step 8, image 2 of 2
    • Detach the blue ribbon that connects the motherboard to the shell casing.
    • Using a Phillips #1 screw driver, remove two 5.4 mm screws to detach the motherboard from the base shell casing.
    Ask FixBot
  9. Alienware AW610M USB-C Charging Port Replacement: step 9, image 1 of 3 Alienware AW610M USB-C Charging Port Replacement: step 9, image 2 of 3 Alienware AW610M USB-C Charging Port Replacement: step 9, image 3 of 3
    • Gently detach the motherboard using your fingers.
    Ask FixBot
  10. Alienware AW610M USB-C Charging Port Replacement, USB-C Charging Port: step 10, image 1 of 3 Alienware AW610M USB-C Charging Port Replacement, USB-C Charging Port: step 10, image 2 of 3 Alienware AW610M USB-C Charging Port Replacement, USB-C Charging Port: step 10, image 3 of 3
    • Turn the motherboard over to the back side. Using a soldering iron at 450 degrees Celsius, and a solder pad, desolder the two points where the USB-C port connects to the motherboard.
    • Remove the USB-C port with a pair of tweezers.
    • Be very cautious when desoldering, as the tool is at high heat and can burn you, as well as damage other parts of the motherboard.
    Ask FixBot
  11. Alienware AW610M USB-C Charging Port Replacement: step 11, image 1 of 2 Alienware AW610M USB-C Charging Port Replacement: step 11, image 2 of 2
    • Align the replacement USB port with the motherboard using a pair of tweezers and proceed to solder the replacement onto the motherboard at 450 degrees Celsius.
    • Gently wiggle the replacement USB-C port to ensure that it is secure.
    • To avoid burning yourself, give the replacement USB-C port time to cool down when connected.
    Ask FixBot
Elizabeth Johnson
85 Reputation
1 Guide authored
Texas Tech, Team 46-4, Johansen Fall 2025 Member of Texas Tech, Team 46-4, Johansen Fall 2025
TTU-JOHANSEN-F25S46G4
4 Members
5 Guides authored
1 Guide Comment
Hi, this mouse have a Micro USB port not a Type-C.
Benjamin Szemok - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 196
