Up to 20% off select tools
Alienware AW610M Side Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
119
All Time:
598
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 25 - 40 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
The side buttons on the Alienware AW610M are responsible for providing short-cuts and in-game actions. After some time, the side buttons may stop working due to wear or build up of debris. Replacing the side buttons allows the mouse to be reliable and work at its best ability.
Before you start replacing the side buttons, make sure the mouse is turned off and unplugged. If you are unsure about the side button being the source of the problem, refer back to our troubleshooting page before you continue.
    1. Alienware AW610M Side Button Replacement, Battery: step 1, image 1 of 3 Alienware AW610M Side Button Replacement, Battery: step 1, image 2 of 3 Alienware AW610M Side Button Replacement, Battery: step 1, image 3 of 3
      • Power off the mouse and disconnect any wired connections.
      Ask FixBot
    2. Alienware AW610M Side Button Replacement: step 2, image 1 of 2 Alienware AW610M Side Button Replacement: step 2, image 2 of 2
      • Use a spudger to gently lift and remove the old mouse feet.
      • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
      • Be careful not to scratch the mouse surface or damage the plastic housing.
      Ask FixBot
    3. Alienware AW610M Side Button Replacement: step 3, image 1 of 2 Alienware AW610M Side Button Replacement: step 3, image 2 of 2
      • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
      Ask FixBot
    4. Alienware AW610M Side Button Replacement: step 4, image 1 of 2 Alienware AW610M Side Button Replacement: step 4, image 2 of 2
      • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
      • Don't pull the halves completely apart, as internal wires still connect them.
      Ask FixBot
    5. Alienware AW610M Side Button Replacement: step 5, image 1 of 3 Alienware AW610M Side Button Replacement: step 5, image 2 of 3 Alienware AW610M Side Button Replacement: step 5, image 3 of 3
      • Remove the battery pack inside the mouse.
      • If you are having trouble, use a small flat tool to help ease it out.
      • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
      Ask FixBot
    6. Alienware AW610M Side Button Replacement: step 6, image 1 of 2 Alienware AW610M Side Button Replacement: step 6, image 2 of 2
      • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
      • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
      Ask FixBot
    1. Alienware AW610M Side Button Replacement, Side Button: step 7, image 1 of 2 Alienware AW610M Side Button Replacement, Side Button: step 7, image 2 of 2
      • Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
      • Detach the cable connector, and remove the scroll wheel.
      • Gently detach the last connector using your fingers.
      • Be careful when unplugging all connectors to prevent tearing them.
      Ask FixBot
    2. Alienware AW610M Side Button Replacement: step 8, image 1 of 1
      • Turn the large shell casing so that the inside faces you.
      • Using a Phillips #1 screwdriver, remove six 5.4 mm screws.
      Ask FixBot
    3. Alienware AW610M Side Button Replacement: step 9, image 1 of 2 Alienware AW610M Side Button Replacement: step 9, image 2 of 2
      • Using your fingers, disconnect the plastic tab in the middle of the large shell casing to access the side buttons.
      Ask FixBot
    4. Alienware AW610M Side Button Replacement: step 10, image 1 of 3 Alienware AW610M Side Button Replacement: step 10, image 2 of 3 Alienware AW610M Side Button Replacement: step 10, image 3 of 3
      • Remove the side button on the inner side of the wall using a plastic opening tool.
      • Be gentle prying the side buttons off to avoid breaking them.
      • When reassembling, position the new side button assembly into the slot, aligning it with tabs. Snap it securely into place using a plastic opening tool or your fingers.
      Ask FixBot
Author
with
Darby Brandt
400 Reputation
2 Guides authored
Texas Tech, Team 46-4, Johansen Fall 2025 Member of Texas Tech, Team 46-4, Johansen Fall 2025
TTU-JOHANSEN-F25S46G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 119
All Time: 598
