Up to 20% off select tools
Alienware AW610M Scroll Wheel Replacement
Views: 18K
View statistics:
Past 24 Hours:
18
Past 7 Days:
94
Past 30 Days:
428
All Time:
17,989
Comments: 3
3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This is a step-by-step guide on how to replace the scroll wheel on an Alienware AW610 Mouse. In this guide, I will be showing you how to disassemble the mouse, replace the scroll wheel, and clean any debris without damaging the hardware.
Sometimes you will notice your mouse's scroll wheel getting stuck or the sensitivity being off. This can be caused by debris and dust trapped between the interior of the mouse or by a worn-out scroll wheel. In this scenario, it is helpful to know how to disassemble the mouse, troubleshoot your issue, and reassemble it without risking your device.
Before beginning, power off your mouse and disconnect it from any devices.
    1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: step 1, image 3 of 3
      • Turn your mouse over with the scroll wheel facing down.
      • Use a precision blade (I used size 12) to loosen the adhesive surrounding any stickers on the back of the mouse.
      • Be cautious with the blade and move in slow, controlled motions as to avoid any injury.
      Ask FixBot
    2. Alienware AW610M Scroll Wheel Replacement: step 2, image 1 of 2 Alienware AW610M Scroll Wheel Replacement: step 2, image 2 of 2
      • Turn your blowdryer on a low heat setting.
      • Precisely aim the heat on the adhesive sections of the mouse for 5-10 second intervals.
      • Turn off your blowdryer, unplug the device, and set it aside to cool down.
      • Carefully peel off the stickers, and set aside as well.
      Ask FixBot
    3. Alienware AW610M Scroll Wheel Replacement: step 3, image 1 of 3 Alienware AW610M Scroll Wheel Replacement: step 3, image 2 of 3 Alienware AW610M Scroll Wheel Replacement: step 3, image 3 of 3
      • Use your Phillips #00 screwdriver to remove four 3.1 screws from the mouse.
      Ask FixBot
    4. Alienware AW610M Scroll Wheel Replacement: step 4, image 1 of 1
      • Gently prop open the back side of the mouse; be careful as to not break any plastic while doing so.
      • Don't pull apart the mouse backing too far, as connections still hold the two pieces together.
      Ask FixBot
    5. Alienware AW610M Scroll Wheel Replacement: step 5, image 1 of 3 Alienware AW610M Scroll Wheel Replacement: step 5, image 2 of 3 Alienware AW610M Scroll Wheel Replacement: step 5, image 3 of 3
      • Disconnect any wire connections away from the mouse's circuit board.
      • Be careful disconnecting the ribbon cable labeled AWM 20706, as you might not be able to reconnect it without damaging the pins, later on.
      • Locate the scroll wheel placed in the gap of the mouse's backing.
      • My scroll wheel was crooked, most likely causing my issue.
      • Gently lift the scroll wheel mechanism out of the mouse's backing.
      Ask FixBot
    6. Alienware AW610M Scroll Wheel Replacement: step 6, image 1 of 3 Alienware AW610M Scroll Wheel Replacement: step 6, image 2 of 3 Alienware AW610M Scroll Wheel Replacement: step 6, image 3 of 3
      • Disconnect the scroll wheel sensor from the mouse backing.
      • Remove the old wheel from the plastic casing, and set it aside.
      • Use a dry cotton swab to wipe off dust or debris in the wheel's plastic casing.
      Ask FixBot
    7. Alienware AW610M Scroll Wheel Replacement: step 7, image 1 of 3 Alienware AW610M Scroll Wheel Replacement: step 7, image 2 of 3 Alienware AW610M Scroll Wheel Replacement: step 7, image 3 of 3
      • Dip a cotton swab into hydrogen-peroxide.
      • Make sure to wear gloves or wash your hands after handling hydrogen peroxide. Be cautious to avoid touching your face in this step.
      • Use a wet cotton swab to clean the mouse backing. Don't hesitate to swipe behind different pieces of plastic as well.
      • Avoid using cotton swabs on the circuit board of the mouse, or any wires in the mouse.
      Ask FixBot
5 other people completed this guide.
Author
with
Rana Ashour
273 Reputation
1 Guide authored
3 Guide Comments
Note: the tan part connected to the ribbon cable IS A RECEPTACLE, THE RIBBON CABLE ITSELF IS THE PART THAT PULLS OUT. I accidentally pulled off my connector, lost a connector pin when attempting to put it back on, mouse still seems to work though.
Nathan - Reply Share
Hello, I followed all the steps but I'm left with the two springs that I don't know where to put. I didn't see the two springs in your pictures.
Morar Razvan - Reply Share
Same, did you find out where it went
ANDREW JOHNSON - Reply Share
Past 24 Hours: 18
Past 7 Days: 94
Past 30 Days: 428
All Time: 17,989
