Alienware AW610M Mouse Feet Replacement
    1. Alienware AW610M Mouse Feet Replacement, Mouse Feet: step 1, image 1 of 3 Alienware AW610M Mouse Feet Replacement, Mouse Feet: step 1, image 2 of 3 Alienware AW610M Mouse Feet Replacement, Mouse Feet: step 1, image 3 of 3
      • Power off the mouse and disconnect any wired connections.
      Ask FixBot
    2. Alienware AW610M Mouse Feet Replacement: step 2, image 1 of 2 Alienware AW610M Mouse Feet Replacement: step 2, image 2 of 2
      • Use a spudger to gently lift and remove the old mouse feet.
      • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
      • Be careful not to scratch the mouse surface or damage the plastic housing.
      Ask FixBot
    3. Alienware AW610M Mouse Feet Replacement: step 3, image 1 of 2 Alienware AW610M Mouse Feet Replacement: step 3, image 2 of 2
      • Take a lint free cloth lightly dampened and clean away any remaining adhesive residue.
      • Allow the surface to dry completely before applying new feet to ensure proper adhesion.
      Ask FixBot
    4. Alienware AW610M Mouse Feet Replacement: step 4, image 1 of 3 Alienware AW610M Mouse Feet Replacement: step 4, image 2 of 3 Alienware AW610M Mouse Feet Replacement: step 4, image 3 of 3
      • Peel the adhesive backing off the new mouse feet. Align the mouse foot with its designated area on the mouse. Press firmly to secure it in place. Repeat steps for bottom mouse foot.
      • Make sure the feet are properly aligned before pressing, as misalignment can affect mouse performance.
      Ask FixBot
    5. Alienware AW610M Mouse Feet Replacement: step 5, image 1 of 3 Alienware AW610M Mouse Feet Replacement: step 5, image 2 of 3 Alienware AW610M Mouse Feet Replacement: step 5, image 3 of 3
      • Power the mouse back on via wired or wireless connection and test the glide and tracking on a smooth surface.
      • If the mouse still tracks poorly, check the surface or sensor for dust or debris.
      Ask FixBot
Ashley S.
171 Reputation
1 Guide authored
Texas Tech, Team 46-4, Johansen Fall 2025 Member of Texas Tech, Team 46-4, Johansen Fall 2025
TTU-JOHANSEN-F25S46G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 43
All Time: 346
