Alienware AW610M Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
31
Past 30 Days:
139
All Time:
769
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your Alienware AW610M mouse won’t power on, can’t hold a charge, or it drains rapidly, then the built-in rechargeable battery likely needs replacement. Our guide will walk you through disassembling the mouse and installing a new battery. Before beginning the guide, make sure to power off the device and unplug it from any charging cables. If you are unsure about the battery being the source of the problem, refer back to our troubleshooting Alienware AW610M Doesn’t Power On page before you continue.
Parts
Tools
    1. Alienware AW610M Battery Replacement, Battery: step 1, image 1 of 3 Alienware AW610M Battery Replacement, Battery: step 1, image 2 of 3 Alienware AW610M Battery Replacement, Battery: step 1, image 3 of 3
      • Power off the mouse and disconnect any wired connections.
      Ask FixBot
    2. Alienware AW610M Battery Replacement: step 2, image 1 of 2 Alienware AW610M Battery Replacement: step 2, image 2 of 2
      • Use a spudger to gently lift and remove the old mouse feet.
      • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
      • Be careful not to scratch the mouse surface or damage the plastic housing.
      Ask FixBot
    3. Alienware AW610M Battery Replacement: step 3, image 1 of 2 Alienware AW610M Battery Replacement: step 3, image 2 of 2
      • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
      Ask FixBot
    4. Alienware AW610M Battery Replacement: step 4, image 1 of 2 Alienware AW610M Battery Replacement: step 4, image 2 of 2
      • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
      • Don't pull the halves completely apart, as internal wires still connect them.
      Ask FixBot
    5. Alienware AW610M Battery Replacement: step 5, image 1 of 3 Alienware AW610M Battery Replacement: step 5, image 2 of 3 Alienware AW610M Battery Replacement: step 5, image 3 of 3
      • Remove the battery pack inside the mouse.
      • If you are having trouble, use a small flat tool to help ease it out.
      • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
      Ask FixBot
    6. Alienware AW610M Battery Replacement: step 6, image 1 of 2 Alienware AW610M Battery Replacement: step 6, image 2 of 2
      • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
      • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
      Ask FixBot
Darby Brandt
391 Reputation
2 Guides authored
Texas Tech, Team 46-4, Johansen Fall 2025 Member of Texas Tech, Team 46-4, Johansen Fall 2025
TTU-JOHANSEN-F25S46G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 139
All Time: 769
