Alienware AW510H Motherboard Replacement
    1. Alienware AW510H Motherboard Replacement, Earpad Cushions: step 1, image 1 of 1
      • Hold the earcup with one hand and firmly grip the ear pad with the other.
      Ask FixBot
    2. Alienware AW510H Motherboard Replacement: step 2, image 1 of 3 Alienware AW510H Motherboard Replacement: step 2, image 2 of 3 Alienware AW510H Motherboard Replacement: step 2, image 3 of 3
      • Rotate the earcup counter-clockwise before pulling it away from the headset.
      Ask FixBot
    1. Alienware AW510H Motherboard Replacement, Microphone Assembly: step 3, image 1 of 2 Alienware AW510H Motherboard Replacement, Microphone Assembly: step 3, image 2 of 2
      • Remove the four 8.5mm screws found on the base of the left ear cup housing using a Phillips #0 screwdriver.
      Ask FixBot
    2. Alienware AW510H Motherboard Replacement: step 4, image 1 of 1
      • Gently lift the plastic shell, being cautious of the wire that is still attached.
      Ask FixBot
    3. Alienware AW510H Motherboard Replacement: step 5, image 1 of 1
      • Remove the 5mm screw from the microphone cover using a Phillips #1 screwdriver.
      • Follow the microphone boom connection to the driver and motherboard.
      • The retractable and bendable microphone is located on the left side.
      Ask FixBot
    4. Alienware AW510H Motherboard Replacement: step 6, image 1 of 1
      • If there is a protective plastic or glue coating on top of the solder, scrape it off using a metal spudger before desoldering.
      Ask FixBot
    5. Alienware AW510H Motherboard Replacement: step 7, image 1 of 1
      • Use a soldering iron to disconnect the wire connecting the microphone to the motherboard.
      Ask FixBot
    6. Alienware AW510H Motherboard Replacement: step 8, image 1 of 3 Alienware AW510H Motherboard Replacement: step 8, image 2 of 3 Alienware AW510H Motherboard Replacement: step 8, image 3 of 3
      • Pull the old microphone assembly out of the housing.
      • If the mechanism is stuck inside, gently push it out from inside the housing, perhaps with the help of tweezers or small needle nose pliers.
      Ask FixBot
    1. Alienware AW510H Motherboard Replacement, Motherboard: step 9, image 1 of 3 Alienware AW510H Motherboard Replacement, Motherboard: step 9, image 2 of 3 Alienware AW510H Motherboard Replacement, Motherboard: step 9, image 3 of 3
      • Desolder the motherboard from the driver casing.
      • Remember to follow safety precautions for soldering.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 163
