Up to 20% off select tools
Alienware 17 R5 Battery Replacement
Views: 12K
View statistics:
Past 24 Hours:
8
Past 7 Days:
40
Past 30 Days:
262
All Time:
11,766
Comments: 7
6 comments on steps, 1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery in your Alienware 17 R5 (model number: ALW17C-D3748S) in the case that your battery can no longer hold a charge. In cases where an old battery will prevent the computer from being able to power on, it can be solved by allowing it to charge for a few hours or days depending on how depleted the battery is. If the battery can't hold a charge, or it is very quickly losing its charge after you have charged it, then it will need replaced. So if your computer only turns on while plugged in, and can only stay on while plugged in, then a battery replacement will likely solve your problems.
Detailed model of the computer:
Name: Alienware 17(R5) (ALW17C-D3748S)
CPU: i7 8750H. 2.2GHz
Graphics card: NVIDIA GeForce GTX 1070 OC
Memory capacity: 8G. GDDR5
Maximum memory capacity: 32G
Weight: 4.42Kg
Length: 424mm
Width: 332mm
Thickness: 29.9mm
Shell color: Silvery
Before using this guide, please note that the computer needs to be completely powered off. This can effectively ensure that you will not be threatened by static electricity when replacing batteries.
ESD safety tools are also necessary.
    1. Alienware 17 R5 Battery Replacement, Remove the Back Cover: step 1, image 1 of 2 Alienware 17 R5 Battery Replacement, Remove the Back Cover: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove all of the screws in the back cover.
      • If necessary, use a plastic opening tool to avoid damaging the back cover while removing it. Make sure that you are unclipping any clips that may be holding the back cover onto the laptop.
      Ask FixBot
    2. Alienware 17 R5 Battery Replacement, Remove the Network Card: step 2, image 1 of 3 Alienware 17 R5 Battery Replacement, Remove the Network Card: step 2, image 2 of 3 Alienware 17 R5 Battery Replacement, Remove the Network Card: step 2, image 3 of 3
      • Lift up the flap that covers the network card.
      • Use a spudger to undo the two wires that connect the network card to the motherboard.
      • Undo the screw holding the network card in. It will pop out at an angle.
      • Remove the network card.
      Ask FixBot
    3. Alienware 17 R5 Battery Replacement, Remove the Second Layer of Casing that Protects the Components: step 3, image 1 of 2 Alienware 17 R5 Battery Replacement, Remove the Second Layer of Casing that Protects the Components: step 3, image 2 of 2
      • Remove the second layer of casing that protects the battery.
      • Make sure not to bend and or damage this layer of casing that protects all of the components while removing it. Remove any screw and or unclip any clip that may be holding it together.
      Ask FixBot
    4. Alienware 17 R5 Battery Replacement, Remove the Cable that Connects the Battery to the Motherboard: step 4, image 1 of 1
      • Use a spudger to unplug the battery cable from the motherboard.
      • Be sure to use ESD safe tools when removing the battery cable.
      Ask FixBot
    5. Alienware 17 R5 Battery Replacement, Remove the Battery: step 5, image 1 of 2 Alienware 17 R5 Battery Replacement, Remove the Battery: step 5, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the screws holding down the battery.
      Ask FixBot
    6. Alienware 17 R5 Battery Replacement, Installing the New Battery: step 6, image 1 of 3 Alienware 17 R5 Battery Replacement, Installing the New Battery: step 6, image 2 of 3 Alienware 17 R5 Battery Replacement, Installing the New Battery: step 6, image 3 of 3
      • Place the new battery in the correct position and reinstall the screws that hold the battery in place. Next , connect the cable into the battery connector.
      Ask FixBot
    7. Alienware 17 R5 Battery Replacement, Reassemble the Device: step 7, image 1 of 3 Alienware 17 R5 Battery Replacement, Reassemble the Device: step 7, image 2 of 3 Alienware 17 R5 Battery Replacement, Reassemble the Device: step 7, image 3 of 3
      • Once the battery is installed, reassemble your laptop completely and test your laptop by turning it on.
      • If your laptop does not turn on, disassemble your device and check to make sure that you did not miss anything, skip a step, that all of the connectors and cables are connected and or connected properly, and or that everything is put back together properly.
      Ask FixBot
    8. Alienware 17 R5 Battery Replacement, Final Tests: step 8, image 1 of 1
      • Wait for your computer to boot up and then sign in. Once you are signed in, click on the icon that looks like a battery in the bottom right corner of the screen to check the battery.
      • If the new battery can hold a charge, stays charged for a few hours, and re-enables you to use your laptop without the charger plugged in, then the new battery is working properly.
      Ask FixBot
Finish Line
9 other people completed this guide.
Author
with
Yubin Qin
268 Reputation
1 Guide authored
1 Guide Comment
This guide needs a lot of work. Step 3 is especially problematic, leaving out the need to remove the panel over the connectors including how to unclip it, also disconnecting the light bars on the sides and the HDD. And how to uncip the plastic panel you are unhooking everything else to do. It needs more than just better pictures. It was enough I didn't feel right giving the credit by saying I'd made the repair (which I did).
Michael Clark - Reply Share
Past 24 Hours: 8
Past 7 Days: 40
Past 30 Days: 262
All Time: 11,766
