Alienware 17 R4 Wi-Fi Card Replacement
    1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: step 1, image 1 of 1
      • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
      • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
      • The M2x3 screw (1.9 mm) does not come out completely.
      Ask FixBot
    2. Alienware 17 R4 Wi-Fi Card Replacement: step 2, image 1 of 2 Alienware 17 R4 Wi-Fi Card Replacement: step 2, image 2 of 2
      • Pull the base cover up to remove it.
      • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
      • Removing the cover may require some force.
      Ask FixBot
    1. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: step 3, image 1 of 1
      • Locate the WI-FI card.
      Ask FixBot
    2. Alienware 17 R4 Wi-Fi Card Replacement: step 4, image 1 of 2 Alienware 17 R4 Wi-Fi Card Replacement: step 4, image 2 of 2
      • Peel back plastic cover of wi-fi card.
      • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
      Ask FixBot
    3. Alienware 17 R4 Wi-Fi Card Replacement: step 5, image 1 of 3 Alienware 17 R4 Wi-Fi Card Replacement: step 5, image 2 of 3 Alienware 17 R4 Wi-Fi Card Replacement: step 5, image 3 of 3
      • Gently undo the clips attached to the wi-fi card.
      • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
      Ask FixBot
    4. Alienware 17 R4 Wi-Fi Card Replacement: step 6, image 1 of 2 Alienware 17 R4 Wi-Fi Card Replacement: step 6, image 2 of 2
      • Locate the cables that connect the wi-fi card.
      • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
      Ask FixBot
Hector Mendez III
1,352 Reputation
8 Guides authored
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Members
108 Guides authored
1 Guide Comment
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 113
All Time: 6,094
