Alienware 17 R4 Solid State Drive (SSD) Replacement
    1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Base Cover: step 1, image 1 of 1
      • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
      • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
      • The M2x3 screw (1.9 mm) does not come out completely.
      Ask FixBot
    2. Alienware 17 R4 Solid State Drive (SSD) Replacement: step 2, image 1 of 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: step 2, image 2 of 2
      • Pull the base cover up to remove it.
      • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
      • Removing the cover may require some force.
      Ask FixBot
    1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): step 3, image 1 of 3 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): step 3, image 2 of 3 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): step 3, image 3 of 3
      • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
      • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
      • Failure to remove the battery connector cable properly may damage other parts of the laptop.
      Ask FixBot
    2. Alienware 17 R4 Solid State Drive (SSD) Replacement: step 4, image 1 of 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: step 4, image 2 of 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: step 4, image 3 of 3
      • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
      Ask FixBot
    3. Alienware 17 R4 Solid State Drive (SSD) Replacement: step 5, image 1 of 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: step 5, image 2 of 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: step 5, image 3 of 3
      • Gently lift the HDD cable to disconnect it from the laptop.
      Ask FixBot
    4. Alienware 17 R4 Solid State Drive (SSD) Replacement: step 6, image 1 of 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: step 6, image 2 of 2
      • Pull the hard drive up to remove.
      Ask FixBot
    1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: step 7, image 1 of 2 Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: step 7, image 2 of 2
      • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
      Ask FixBot
    2. Alienware 17 R4 Solid State Drive (SSD) Replacement: step 8, image 1 of 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: step 8, image 2 of 2
      • Slide the solid state drive towards yourself to prevent damage to the card.
      Ask FixBot
3 other people completed this guide.
Hector Mendez III
1,352 Reputation
8 Guides authored
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Members
108 Guides authored
1 Guide Comment
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
John Crooks - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 120
All Time: 7,970
